This a Bad Sensor?????????
Old Feb 4, 2010 | 07:04 AM
jarven93's Avatar
Icon2 This a Bad Sensor?????????
I have a 93 civic d16z6..... while driving my car runs Great, smooth (car warmed to temp), air/fuel at 14.5..... but when i approach a stop light, and push in the clutch to coast to a stop RPMs drop to idle but then begin to jump between 750 and 1500rpms while still rolling. air/fuel drops as well to 17.5 to 20. back to 17.5 then back to 20. ect... but as soon as the car comes to a stop the idle starts to smooth out at 850rpms and air/fuel goes back to 14.5 Also if i let the car idle for like 5 to 10min. after its warmed up the air/fuel will just drop off and jump between 17.5 to 20. then shortly after check engine light comes on? is this a bad sensor??? if so what sensor? any help please... thanks guys.....
Old Feb 4, 2010 | 08:57 AM
jarven93's Avatar
Default Re: This a Bad Sensor?????????
bump>>>
Old Feb 4, 2010 | 11:54 AM
jarven93's Avatar
bump< anyone???
Old Feb 5, 2010 | 07:00 AM
jarven93's Avatar
last bump....
Old Feb 5, 2010 | 07:20 AM
NonovUrbizniz's Avatar
Loved
sounds like a bad IACV.
This would probobly be better off posted in the tech section or the civic section.
Old Feb 5, 2010 | 10:33 AM
AbitAvenger's Avatar
I would pull off the IACV and clean it with some brake cleaner. Is the car tuned?
Old Feb 5, 2010 | 05:15 PM
jarven93's Avatar
k i pulled it off looked pretty clean still, the only thing i can think of is that i just recently put on 550cc rc injectors and am tuning with a vafc2 . the car ran fine with stock injectors....
Old Feb 5, 2010 | 05:19 PM
CoreyR's Avatar
it amazes me people still use afc hacks when you can chip an ecu and buy a chip burner for less then half the price.
your problem is your 1999 tuning hardware.
Old Feb 5, 2010 | 07:30 PM
TehGhett0P1mp's Avatar
I agree these kids never learn =/
Old Feb 5, 2010 | 11:01 PM
Put your stock injectors back in. Set the afc back to stock or default settings or whatever. The car should run fine after that.... If you're boosted I wouldn't be hitting any boost yet either...
Lookup xenocron or phearable and have them burn you a basemap for your setup so you can drive it to someone to get tuned(if you ecu is chipped, if not find a p28 and have it chipped or buy on from a vendor). the afc hack is ghetto and not worth anyones time anymore when decent engine management is available
Bocan
Honda Civic (2006 - 2015)
20
Aug 15, 2014 05:05 PM
dc4b20
Nov 21, 2012 05:58 AM
ls19integra95
Jan 15, 2008 02:01 PM
B_1_8_hatch
Apr 28, 2003 05:21 PM
