Bottom End/Balancing question
Old Jan 26, 2010 | 08:40 PM
96GeeSR's Avatar
Default Bottom End/Balancing question
I have a 96 gsr motor and machine shop bored it out to 81.5mm. i got wiseco pistons and eagle rods for it. new honda bearings, stock crank, just polished. ctr cams, cometic hg, mild port/polish on head. and a drag turbo kit. the machine shop recommends i have the crank balanced because of the aftermarket rods. i am a bit tight on cash as i spent some money on all new parts and i was wondering when you guys do your builds do you just put in your rods in you used aftermarket and how bad is it if i dont have it balanced?
Old Jan 27, 2010 | 09:12 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Bottom End/Balancing question
99% of the time you will not need them balance fyi
Old Jan 27, 2010 | 09:19 AM
dart2.2's Avatar
how about a ls crank spinning 10.5k?
Old Jan 27, 2010 | 12:59 PM
THEUSED's Avatar
Why half *** it? you have it all apart and at the machine shop why not just have it balanced, its not very much money, if you cant afford to balance it then you should be building it, I would and am bringing everything I can when I have my block machined and balanced including the crank, rods, pistons, Harmonic Balance, flywheel, and clutch, Unless you dont care about how long your build lasts or how it runs,
Up to you but why risk it?
Old Jan 27, 2010 | 01:02 PM
96GeeSR's Avatar
thanks for the replies. i was just looking for a quick answer since this is my first "build". gonna get it balanced.
Old Jan 27, 2010 | 01:55 PM
alpha's Avatar
Have the crank balanced and micropolished. That's all you will need from the sound of your setup. Put the money elsewhere
Old Jan 27, 2010 | 02:25 PM
96GeeSR's Avatar
having full rotating assembly balanced, crank has been polished thanx..
Old Jan 27, 2010 | 02:59 PM
ive built quite a few setups, unless you plan on revving it to 11k and making 700hp i wouldnt worry about it, just make sure your cranks bearing surfaces are polished
jdm_special
Engine Machining & Assembly
May 11, 2019 11:17 PM
CHU-JDM-DC2
Feb 1, 2016 12:52 PM
CK_4500
10
Jun 24, 2009 06:42 AM
Darkane
Oct 12, 2005 12:37 PM
shingles
Nov 21, 2001 02:46 PM
