spoolin a-spec
Old Jan 28, 2010 | 08:36 PM
12345's Avatar
Default spoolin a-spec
Is anyone here running the spoolin a-spec manifold on a b-series? If so, how did you make your oil return line? I'm having a pain of a time doing mines because of how low the turbo is in relation to the oil pan flange. Thanks for any help!
Old Jan 30, 2010 | 06:10 AM
Silva Bullit DC4's Avatar
Default Re: spoolin a-spec
I run one. What I did was run a regular straight 1/2" brass push lock fitting from the turbo drain, & clocked the CHRA almost 45 degrees. For the oil pan, I welded a 1" to 1/2" reducer bung to the pan, then ran the same size brass push lock fitting to that bung, cut my oil drain line to size, and it worked out nicely.
I'll post pics soon. Too much snow out right now, 14 inches!
BoostThisMS
Jan 25, 2013 08:46 PM
be18see1
Feb 16, 2011 06:15 AM
Luis Valdez
Honda Civic (2006 - 2015)
Feb 8, 2009 06:03 PM
BEEYOND
Sep 2, 2004 01:08 PM
dunkd
Mar 8, 2004 09:07 PM
