HELP! Picking out cams for a boosted set up!
Old Jan 31, 2010 | 06:00 PM
scspeed's Avatar
Default HELP! Picking out cams for a boosted set up!
My motor setup is:
Head: b16 head, very stiff valve springs, deffenetly aftermarket springs but not sure exactly what kind, stock resurfaced valves, valves are nitrate coated, and its got titanium retainers... Also im using a skunk 2 ITR manifold, 880cc PTE injectors, B&m FPR, and an AEM fuel rail.
Bottom: gsr block, JE pistons, eagle rods (9:1 comp ratio), ACL racing bearings, stock bore, ARP head studs, block was built for boost...
I made 389whp at 319foot lbs of torque last year with a stock head and cams at 18lbs of boost (turbo is comparable to a GT30R). Now i have the head written above ^^ and i want to get a pair of nice cams to allow for more airflow so that i can make more power in the long run, oh and also i have Tru time AEM adjustable cam gears as well...
Ok so my goal is this year with the new setup is to make at least 450-470whp but i need some advice on which cams i should go with and maby even where to set my rev limiter with the new cams. Thanks guys!
Old Jan 31, 2010 | 07:10 PM
Silva Bullit DC4's Avatar
Default Re: HELP! Picking out cams for a boosted set up!
With that power goal, it is easily attainable with ITR or CTR cams, a tried & true alternative to aftermarket cams for a goal of that range, and will make a considerable gain over the B16 bumpsticks.
And if your turbo is in fact comparable to a GT30R (depending on dimensions), you should be set in your quest for 450-470. Your rev limit will depend on you and what the purpose of the car will be. Also state the dimensions of your turbo.
Old Jan 31, 2010 | 08:20 PM
TwoKSiR's Avatar
Anything more than ITR cams would be pointless and money poorly spent right now. ITR is good WELL past your power goals.
Old Jan 31, 2010 | 08:51 PM
Schister66's Avatar
Man U FTW
My thoughts exactly. You could also look into the Blox B's which are very similar to the ITRs...because sometimes its hard to find a set of ITR cams on a moment's notice
Old Feb 1, 2010 | 09:57 AM
scspeed's Avatar
ok, well i do have an gsr intake and a ITR exaust maby ill just use that, its prolly gunna be really hard to find just one itr exaust cam...See teh reason i wanted a cam made for boost was becouse i wanted to spool my turbo faster as well, would a cam larger tahn an itr do that better??
Also yes the turbo is very compairable, im not sure of the exact dimentions i always forget but when i got it dynoed last spring its boost curve was almost dead on to a 30R with the same setup if that helps you any...
I would think my block could take the 70hp gain with out an issue? It is in very good shape still, compression is right on.
sdime94
Dec 22, 2012 11:01 PM
spags930
Apr 5, 2010 12:20 PM
killah1
Nov 14, 2007 08:06 PM
spoonhatchblack
Oct 5, 2007 11:10 PM
CeeJayy
Feb 25, 2007 11:22 AM
