benson block and copper head gasket ?
Old Jan 21, 2010 | 09:21 AM
bzyq2001's Avatar
Default benson block and copper head gasket ?
what do you think guys about bensos sleeved b18c with SCE (copper) head gasket ?
it will be street car (not dd), almost everybody use MLS gaskets, why not copper?
Old Jan 22, 2010 | 05:47 AM
darkvader0's Avatar
Default Re: benson block and copper head gasket ?
I can't give you advice for the SCE gasket, but I am replacing my Benson 84.5mm B18C with a Golden Eagle 84.5mm head gasket.
Old Jan 22, 2010 | 12:21 PM
CerealKiller's Avatar
OEM or bust.
Old Jan 22, 2010 | 12:23 PM
hybrdthry911's Avatar
why copper when the OEM gasket works perfect for any power level.
Old Jan 22, 2010 | 12:27 PM
HiProfile's Avatar
Go to a hardware store and find some copper & stainless wire - try bending both... Copper is only if you're removing the head constantly. Copper o-rings are the only copper I'd use for a Honda block.
Get a bunch of OEM's from an online dealer shop and be done with it. If you search, hondapartsdeals has a honda-tech code for free shipping or something.
Old Jan 23, 2010 | 11:17 PM
civic_r87111's Avatar
My opinion on the copper gaskets is that copper is suck a soft metal and has a greater potental for blowing out, compresses and seals great tho but I wouldn't trust it under high cylinder pressures.
Old Jan 24, 2010 | 03:47 AM
bzyq2001's Avatar
becouse i have one on the shelf
drag cars are using copper gaskets and they have preaty big pressure ratios, i'll have no more than 30psi
Old Jan 26, 2010 | 11:09 PM
ninesecrx's Avatar
Copper gaskets sometimes have issues leaking coolant and oil. I would stick to steel gaskets.
Old Jan 27, 2010 | 03:20 AM
crashsvg's Avatar
speaking from experience..they are good for low power but imo anything after 250whp the tend to give alot of probs..
when i moved from 7 to 15 psi on my stock b16a set up it start leaking water in the cylinders thus pressurizing my engine and caused engine lock.
they suck a lot of heat though but thats about the only good thing..they are just not strong enough to cope with high hp numbers they bend to easy under pressure.
Old Jan 28, 2010 | 06:09 PM
blackeg's Avatar
i also use the golden eagle gaskets on my benson 84mm block
strigga
Sep 28, 2018 05:58 PM
Muckman
Apr 6, 2018 11:25 AM
sickerhatch
Apr 16, 2005 10:14 AM
hondafanatic1
Feb 19, 2004 05:35 AM
