ls/vtec help help
Old Jan 17, 2010 | 10:18 AM
acuraturbo90's Avatar
Icon6 ls/vtec help help
hello people form h-t i have a Q for those maybe had the same problem like me or more like a guru in this problem.... i used to have a b16 turbo with a suppost a bad piston slap which was prove wrong by a machine shop but no satisfied i change to ls/vtec with new block from a local shop send it to get built with micro polish crank ,acl bearings kit arp bolt from bottom to top,,ctr cams, eagles rods, je pistons n je rings new, oil pump, w/pump, new ls timing kit ,b16 head w/sk2 valves spring retainers n p/p ready to boost the engine has right now close to 500 millage not even break in yet but the big problem is the engine make a bad noise coming from the head and i about to give up i adjust and re adjust the valve thinking the was a valve lose but no i take a part the head my self and put a new set of lam's another set of rocker arm complete and still sound like a tractor pls any help i appreciate it
Old Jan 17, 2010 | 11:13 AM
iamthefollower's Avatar
Default Re: ls/vtec help help
is it like a loud ticking noise or what does the noise actually sound like?
Old Jan 17, 2010 | 01:49 PM
JdMtR's Avatar
could be low on oil, god damn lsvtecs
Old Jan 17, 2010 | 04:25 PM
thanks for the response...... n yes is a loud ticking like tick tick tick tick especialy when the engine is super cold is like is not get in oil on top but i took off the valve cover and man i start the car n it make a mess w/oil all over oil p.s.i is 80 cold 35 when is hot press the gas n go up to 80 again when the engine warm up it quite just a little but you drive it runs fine but if you push it around 2,500 up to 4,500 sound like crazy lose valve and they are perfectly adjust it drive me crazy ... u think is bad head ??? i send another one to the machine shop just in case
Old Jan 17, 2010 | 08:27 PM
What kind of oil pump did you put in the motor? Have you check to make sure everything in the head is tightened??
Old Jan 17, 2010 | 08:31 PM
mayfly's Avatar
did the machine shop check for valve clearance? could be a possibility
Old Jan 18, 2010 | 05:02 AM
kyden's Avatar
check your lost motion assemblies.
Old Jan 18, 2010 | 05:11 AM
i have stock ls oil pump why is bad ?? which one should i use ? i check twice the head and everything still tight. see i was running 5w30 to break the motor i change to 10w30 to see if the noise go away because of the thickness but nope still there is weird man even i took the car to the machine shop n the guy said the same thing weird he told to take the head off and bring it to double check because he adjust the valve almost dead end n still sound like diesel truck any help is appreciate it thanks
Old Jan 18, 2010 | 05:13 AM
i change the lma's twice man and nothing
frustration is killing me
Old Jan 18, 2010 | 03:10 PM
madking411's Avatar
^^you're gonna wanna change that stock ls oil pump ASAP, what year is the block??
If its a 1996+ block, then your oil pump will be fine as-is because they all come with P72 pumps... but if not, better change it QUICK, i had an LSvtec blow up on me in 5 days due to the pre-1996 stock ls oil pump being on there...
And all that extra noise you're hearing is most likely the head starving for oil. The pressure numbers could be correct, but the volume of oil actually being pumped could be not enough.
Old Jan 18, 2010 | 04:38 PM
you know what your right the block is the 1st gen how i mist that thank you so much i will change that asap
Old Jan 18, 2010 | 06:23 PM
i'm glad they got to answer that about your oil pump for you, I was asking cause I was going to tell you the same thing lol. I'm glad they told you. but yet just get that changed out and see what happens from there.
Old Jan 18, 2010 | 09:38 PM
thanks all of you for the help i will let you guys know tomorrow.
will i did work in my car today and i did change the oil pumpi put a j-spec b16 plus i put a little washer between the spring inside so i created more pressure ......here comes the but ......but the noise still there idk what else could be it sound right in top like the in the valve train i check i re adjust the valve and no luck i think i going to pull the head off and take it to the machine shop for inspection
superhatchbackbros
Oct 6, 2010 03:49 PM
1993gsrcivic
Nov 5, 2009 08:02 PM
paton5g
21
Mar 17, 2009 02:04 PM
ddtfrom626
Jun 14, 2008 12:07 PM
myke5505
Mar 15, 2005 12:03 PM
