need help with vacuum lines
Old Jan 17, 2010 | 11:14 PM
dcintegra88's Avatar
Default need help with vacuum lines
so i got a greddy bov, a tial wastegate, a precision turbo, turbo xs mbc, and a boost guage. how would i hook all these up to a blox vacuum manifold. would i have to t off where the wastegate connects to the boost controller and run it to the vacuum manifold?
Old Jan 18, 2010 | 01:04 AM
cleansi's Avatar
Default Re: need help with vacuum lines
never t off any thing that connects to the wastgate the wg should always have its own vacuum source
if you look though the FAQ they have some good step by step instructions fo running/installing bov vacuum lines ect
ive set mine up by whats posted here in the faq and my local tuner was surprised...
Old Jan 18, 2010 | 09:41 AM
zedron's Avatar
1) Run a vac line from bottom of wastegate to silver port on MBC and then another vac line from compressor housing on turbo to other port on MBC. This is done, don't change it.
2) Put the blox vacuum manifold in line with the brake booster using T provided. Run BOV, Boost gauge from it and block all other unused ports off.
Old Jan 18, 2010 | 10:35 AM
Thanks guys for the info. One more question...do I leave the bottom port on the bov open?
Old Jan 18, 2010 | 10:41 AM
kyden's Avatar
yes
Old Jan 18, 2010 | 11:15 AM
zedron's Avatar
What type of Greddy BOV is it? There shouldn't be more than one vacuum port on it. The thing on top should be only an adjustment screw.
Old Jan 18, 2010 | 11:39 AM
It's a greddY rs bov. And it has two nipples on the backside of it one higher the other lower.
Old Jan 18, 2010 | 11:48 AM
zedron's Avatar
Can you post a pic of it. I have a RS too and it only has one. I even just googled images and they all have one too.
EDIT: Seems you have a Greddy S. As posted above dont use the smaller/bottom nipple.
Old Jan 18, 2010 | 11:52 AM
kyden's Avatar
are you sure you don't have the type s?
Old Jan 18, 2010 | 12:00 PM
I'll post pics up in a bit.
Old Jan 18, 2010 | 01:14 PM
It is the greddy type s bov. So would I just leave the bottom nipple open?
Old Jan 18, 2010 | 01:29 PM
zedron's Avatar
Yes
Old Jan 18, 2010 | 01:36 PM
Ok thanks alot!
Old Jan 18, 2010 | 01:42 PM
cleansi's Avatar
the bottom nipple is suppost to be t between the wg and boost controller most people leave them open
b18psi
Aug 20, 2018 06:05 AM
19_HaTcH_92
Feb 20, 2010 03:24 PM
draconx
Mar 15, 2006 06:03 AM
jdm-ray
May 15, 2005 09:37 PM
abmerop18
Mar 9, 2005 09:28 AM
