My First SOHC Build, need input
Old Jan 18, 2010 | 08:30 AM
jksmith's Avatar
Default My First SOHC Build, need input
New to the forums, so Hi to everyone.
I am about to start my first every SOHC build, done several BSeries and a HSeries build but wanted to try something different.
Just looking for some input on if im going to wrong route, here is my build sheet
Looking for ~400whp on E85
Starting w/ a D16z6, going to be a fresh build so all new pumps and gaskets
Bottom End:
75.5mm Vitara Pistons
Eagle H Beams
Balanced Polished Crank
ACL Bearings
Top End:
Mild P&P
Bisimoto 3.6 Cam - Still need
Bisimoto Cam Gear - Still need
Bisimoto Springs & Retainers - Still need
SS Valves (havent decided on brand yet) - still need
RC 1000cc Injectors
AEM FPR
AEM Fuel Rail
Skunk2 Intake Mani
Skunk2 60mm TB
Tranny:
I have a Si w/ a LSD, but have been reading into the DtoB conversion so i might eventually try that, with my JDM Type R Tranny i had from my B Build
FI:
- Still NEED Everything here!
GoAutoworks IC & Piping
Some form of a Ramhorn Manifold
Precision Billet 6262
Tial 44mm WG
Tial BOV
Electronics:
AEM Wideband
RTP Neptune
Old Jan 18, 2010 | 09:02 AM
welfarepc's Avatar
Default Re: My First SOHC Build, need input
good call going with go-autoworks. good people there! they can make you a killer ram horn manifold and downpipe/dump tube combo as well.
with your parts list, you can easily make the power you want.
that turbo is going to spool late so be ready to take the car to 9000rpm or higher.
Old Jan 18, 2010 | 10:08 AM
jksmith's Avatar
k, think i should go with a smaller turbo, still havent got anything yet so options there are open, but i def. want to use a Billet turbo, heard good things about them and wanna try one out.
Old Jan 18, 2010 | 04:13 PM
Boosted-EH-804's Avatar
6262 might be a bit much fro just 400 hp 57 trim will get you that and cost you much less and give you a better powerband.....
Old Jan 19, 2010 | 04:21 AM
VtecCarHauler's Avatar
Good parts list. If you go 6262 it is going to make you go for 500whp (not a bad thing). If it is a daily driver you might want a smaller turbo but I would prefer the bigger turbo for the top end power. 6262 will do 400whp easy and you could have a high boost tune for 500whp+. My friends car was on a GT35R and it was not too laggy. They rev that car to 8000rpm and sometimes 8500. We are going to a 6262 in a week or so. As far as the B2D trans swap we are working on it. Get a good pressure plate and decent clutch and get your setup up and running with the D-series box. Once we finish the B2D we will do a full right up. There is some info on the B2D but no solid proof.
d16z6 block
-10:1 cp/eagle rods
-stock sleeves
-no block guard
d16z6 head
-no porting
-valve springs and retainers
-comp cam part#? (it works whatever it is)
-Y8 Oem Mainfold
-GSR TB
turbo setup
-1000 cc injectors
-dual walbros
-hondata s3
-ram horn manifold
-44 tial
-GT35R .82
-3 inch charge piping
-custom catch can
-E85
http://www.youtube.com/watch?v=1k4rTDGY6vU
superhatchbackbros
14
Oct 18, 2010 07:50 AM
fatboys_ef9
Oct 1, 2008 06:02 AM
beasty=eg
Mar 23, 2008 03:32 AM
sohcvtec97
May 2, 2005 07:40 AM
Tad
14
Dec 3, 2004 09:13 PM
