tillton flow control valve?
Old Jan 31, 2010 | 06:09 PM
runsfromdacops's Avatar
Default tillton flow control valve?
im lookin to see if any one knows what fittings i need to to put the flow control valve in with the stock master and slave. do i have to replace to hard line or can i convert it to -3 at the stock soft line?
-alex
thanks guys
Old Jan 31, 2010 | 06:11 PM
B20luda's Avatar
Default Re: tillton flow control valve?
just have a new line made, or all you need to do is have 2 -3 female fittings crimped to the fexible part of the line... Brian has one on his car im sure he did the same thing i did..
Breaking trannies?
Old Jan 31, 2010 | 06:53 PM
BlakeJ53's Avatar
I just replaced the whole hard line with a -3 steel braided.
Old Jan 31, 2010 | 07:07 PM
i would rather leave the hard line if possible. adn i dont know what fitting i will need to go from the the stock stuff to the -3, as in what is the flare on the is on the end of the hard line and on the slave
Old Feb 1, 2010 | 06:48 AM
YARO.'s Avatar
brian @ b&r fittings has the kit to replace the hard line with a -3 steel braided line and the fittings for $65. I'm sure he can make you something to work with that for not much extra.
jthelman
Sep 11, 2002 01:49 AM
ceemarun
Jul 19, 2002 11:57 AM
