what size injectors to use?
Old Jan 23, 2010 | 07:13 AM
Luke G.'s Avatar
Default what size injectors to use?
Ive been having mixed answers on what size injectors i should get, Basically the setup will be gsr engine around 12psi, 350whp. Ive just got so many mixed answers about this im not sure what to get? I was originally going to get precision 650cc high impendence injectors..
Old Jan 23, 2010 | 07:39 AM
nasolja's Avatar
Default Re: what size injectors to use?
Rule of thumb is take the injector size and add all 4 together, then divide by 5. This would be an estimate of what the injectors can handle. For your application you should be safe running anything over 550cc and you would still have room to add boost later without changing them. I've never used and aftermarket company (always dsm or rx7) so i can help you there. Here are some OEM options if you have access to them.
1988 RX-7 (Purple top 195500-1370) - saturated/high imp. - 550cc
1989-91 RX-7 (Purple top 195500-2020) - saturated/high imp. - 550cc
hope this helps
Old Jan 23, 2010 | 09:02 AM
Luke G.'s Avatar
alright, i guess i will just stick with precision 650's unless informed otherwise.
Old Jan 23, 2010 | 09:08 AM
Speed_1's Avatar
Just curious why not get some ID1000's and you will have plenty of room to grow later on down the road.
Old Jan 23, 2010 | 09:20 AM
Luke G.'s Avatar
im not going any higher than 350hp though, i dont see the reason to go that big
Old Jan 23, 2010 | 10:25 AM
zedron's Avatar
650s will be just fine for your setup. ID1000s are good but cost more and if you dont plan to ever need bigger ones then dont spend $ that you dont have to.
Old Jan 23, 2010 | 11:53 AM
Luke G.'s Avatar
alright cool, thanks for clearing things up for me.
DC2fab
Apr 9, 2010 09:31 PM
alexb16hb
May 13, 2006 10:18 AM
bjfisher
Dec 17, 2005 06:34 PM
See Are X
Dec 14, 2005 07:29 AM
Change
Sep 25, 2004 08:24 PM
