b18b whp tolerance...
Old Jan 19, 2010 | 06:07 PM
mikej94civex's Avatar
Icon2 b18b whp tolerance...
they say max 200whp for d series stock internals, and i kno the b series are stronger, so
how much whp, roughly, can a stock b18b hold...j/w because my d series boosted is only for the
next yr while i get rdy for my swap, i plan to push 12psi on the b18b, thanks in advance!
btw my whp goal is 250-275 if that matters.
Old Jan 19, 2010 | 06:34 PM
Schister66's Avatar
Man U FTW
Default Re: b18b whp tolerance...
Generally, stock internal B series are safe into the low 300whp range with a good tune. Don't base your goals in terms of psi...as others will inevitibly tell you, it is an irrelevant measurement. Read through the FAQ if you want to know more...
Old Jan 19, 2010 | 06:47 PM
i understand not to base my goal on psi...that's y i gav u my goal of 250-275...i just said
12psi as to what i was goin to run, thanks tho for the reply on the amt the b can handle
Old Jan 19, 2010 | 06:53 PM
is the 250-275whp goal realistic with a stock ls on 12psi, with a good tune?
Old Jan 19, 2010 | 07:19 PM
ME=ADRIAN's Avatar
yes its very realistic. look in the ls-t thread..you will find hundreds of pages of b18a/b info..
Old Jan 21, 2010 | 06:02 PM
blackeg's Avatar
absolutely realistic goal.
at 240hp i ran my 215k mile stock ls motor through hell (overheated it, ran it way lean on the dyno etc. still ran like a champ when i took it out to go vtec)
Old Jan 21, 2010 | 07:13 PM
iamthefollower's Avatar
Very realistic, as others were saying they have a ton of them in the LS-T forum.
Old Jan 23, 2010 | 10:57 AM
awesome, thanks for all the great info, i'll b checkin out the ls-t threads
as well now
Old Jan 23, 2010 | 01:57 PM
Silva Bullit DC4's Avatar
OP, your tuner will use whatever psi your setup will give him to make 275 whp. It may take less psi to get that goal, or it may take more, it all depends on whatever size turbo you will be using.
Psi is just the level of pressure measured at the intake manifold & MAP sensor, so in your case, dont let the amount of psi concern you.
Anthrolude
12
Feb 19, 2006 08:26 PM
TurboJesse
Jun 9, 2003 03:17 PM
SohcVtecCrix
Mar 2, 2003 07:38 PM
BorderM3
Feb 12, 2003 01:46 PM
Endles
Sep 27, 2002 06:54 PM
