stock b18 map sensor
Old Jan 27, 2010 | 08:04 PM
SnailedEG's Avatar
Default stock b18 map sensor
can the stock map sensor read .7 bar(10.29lbs) i know it can read up to 10 but will it go 10.29?
Old Jan 28, 2010 | 12:01 AM
Terrible One's Avatar
Default Re: stock b18 map sensor
my hondata s300 read 10.5psi on a stock map sensor, no issues.
Old Jan 28, 2010 | 10:40 AM
dpetro1's Avatar
from a good tuner, John Kerr
Originally Posted by 93turbo16
the stock map sensor outputs a max voltage of somewhere around 4.78 volts or so (0-5v sensor). Which equates to around 10.2 - 10.7 psi, depending on altitude. At this voltage the ecu will read off the last boost column in the map, which happens to be 10.7psi on most ROM editors.
so basically the stock map sensor should be fine as long as you have a chipped ecu with boost columns added. even if you do get slightly more boost, you will stay at max voltage and read off the last boost column.
Old Jan 28, 2010 | 12:52 PM
SnailedEG's Avatar
ok cool thanks
daflagger
Nov 4, 2007 08:31 PM
yoffer
Jul 30, 2007 03:05 AM
B16Drag
Jan 25, 2006 06:59 AM
HiGhCaM
May 11, 2002 11:40 PM
DIRep972
Mar 11, 2002 07:01 PM
