tapping oil pan
Old Aug 28, 2001 | 09:10 PM
Peter K's Avatar
New User
Default tapping oil pan
just wonderin where some of you guys tapped the oil pan ..what do you guys think of the moroso oil pan? is it worth it? anybody with prices on it?
[Modified by sxychnamn, 6:11 AM 8/29/2001]
Old Aug 28, 2001 | 09:20 PM
synthtk's Avatar
New User
Default Re: tapping oil pan (sxychnamn)
for my civic w/ DRAG g3 i tapped the pan pretty much straight down from where the turbo oil return is.. you can see a pic here..
http://www.tiora.net/~chris/index.ph...g=DSC00011.JPG
seems to work ok..
Old Aug 28, 2001 | 11:08 PM
degradated's Avatar
New User
I always see pictures of pans tapped for the oil return line, but never see anything about the oil feed line. Doesn't the pan have to be tapped for that too from the back of the pan? I'd like to see more pictures of that...
Old Aug 28, 2001 | 11:23 PM
liam821's Avatar
25 Year Member
Default Re: tapping oil pan (degradated)
the oil feed line comes from the oil pressure sensor normally...not the oil line. The oil going into the turbo is under high pressure (whatever the oil pressure of the engine runs at) and goes through a small metal hose. Normally you unscrew the stock oil pressure sensor on the back of the engine, insert a T off that and run a line to the turbo and then screw the stock pressure sensor on the T.
The oil which comes out of the turbo is like a foam. After oil goes though a turbo spinning at 80,000 rpms....its just a foam. Thats why the line from the turbo to the oil pan is 3/4" or something thick..its not really liquid anymore. Although once it gets into the oil pan it will mix with the other oil..
liam
Old Aug 28, 2001 | 11:24 PM
lucas569's Avatar
the oil FEED line comes off the back of the block T'd off the oil pressure sensor,not the pan...
Old Aug 28, 2001 | 11:53 PM
C-speed's Avatar
Default Re: tapping oil pan (lucas569)
Check here for pics:
http://www.c-speedracing.com/howto/v.../vortech4.html
HTH
Old Aug 29, 2001 | 11:09 AM
integRated109's Avatar
Default Re: tapping oil pan (G3-TEG)
i just cut a hole and welded a nut onto the outside of the pan, then threaded the hose fitting into the nut. seems to be working fine. i have better things to spend 400 bucks on than a oil pan........like more dyno runs...........
Old Aug 29, 2001 | 09:58 PM
degradated's Avatar
New User
Default Re: tapping oil pan (liam821)
cool...thanks.
solo2fresh
Mar 2, 2011 04:09 PM
ashb82
Mar 22, 2010 12:50 PM
swatteamtimmah
May 7, 2006 04:19 PM
BoostedH23a1
Oct 24, 2002 07:56 AM
GruvyTune
Nov 18, 2001 03:59 PM
