Is it boost or horse power that ruins engines?
I was talking to Bryce at Alamo autosports in Arlington about what grenades engines all things being set up right. Bryce was telling me cylinder wall flex is the downfall of enignes (even properly tuned ones). This I think is generally known. He further told me horse power is the cause of the flex. This is where things get fuzzy for me. I thought hp was a function of psi and psi is the cause of wall flex. He was telling me 320 whp is the limit of nonsleeved blocks. If this is the case then around 12psi (drag kit) is the max psi for the vtec blocks and 17 psi for the LS blocks. Can someone clear this issue some. If 320 is the most I can run on a non sleeved block reliably, then I won't bother getting the map sensor upgrade for the Hondata. oh yeah I'm running eagle rods, pistons, oxide coated valves.
Sorry for the long post
New User
Re: Is it boost or horse power that ruins engines? (b18bpwr)
You've pretty much got it. Too much cylinder pressure will make the walls flex. Cylinder pressure is created by both boost and compression. Since the B18C has a higher compression ratio than the B18B, boosting 12psi on a B18C will bring the max combustion pressure to very roughly the same pressure as boosting 17psi on a B18B. Very roughly, but you get the idea.
Detonation raises the cylinder pressure much higher than that of controlled combustion, so frequently it's detonation that kills engines.
New User
Re: Is it boost or horse power that ruins engines? (mercury)
almost got it. Cylinder pressure (or combustion pressure) is directly related to how much fuel, ignition timing, cam timing, boost pressure, etc. It's all relevant. So, in theory, horsepower could be used as a greater gauge of cylinder pressure than boost itself. Really it all boils down to one thing - tuning. Detonation is your single most worst enemy, period. Great question and answers though!
New User
Re: Is it boost or horse power that ruins engines? (Ray)
in my estimation, if you have a GEM block, rods, pistons, and a balanced assembly, you have very few weak links. The next step in the chain would be the oil pump, which will sometimes shatter at power above 350whp. Prodrive and Toda have solutions for that. If you've done these things, I'd concentrate on making sure bearing clearances are exactly in spec, deburr the interior of the block for improved oil circulation, and have the crank access holes drilled out, fully cleaned, and tapped for plugs so future cleaning would be easier. You could go on and on in the block, but most of the things I outlined here will cover you up to insane power levels.
Re: Is it boost or horse power that ruins engines? (VaporTrail)
I'll be happy with around 350whp on my b20 thats reliable. Of course if the dyno puts up higher.
I'm thinking bout buying cam gears, do you guys think 210 is right for JUN cam gears?
So if I understand this correctly, since around 320 whp is the most I can get on stock sleeves safely, I can go with a smaller turbo (read quicker spool up) and up the boost to my hp goal? Right about now I wish I would of resleeved. It's my only week point, however money had to go to pay tuition Still this should be enough...hopefully
Oh yeah, I'm definitely dyno tuning.
[Modified by b18bpwr, 6:29 AM 8/23/2001]
New User
What about using a GSR style girdle on the LS. Do you guys thing that may help with the flexing. Also what about a block guard. The reason I ask is I have an LS with a block guard, stock LS girdle and stock sleeves that is runnning 11.9s so I have to be getting near that sort of power output and I am always looking for ways to strengther the block.
New User
Re: Is it boost or horse power that ruins engines? (boosted97)
the girdle is going to save your bearings more than anything else. Z10 Engineering makes one specifically for the B16/18a/20. http://www.z10eng.com
Smarter than you
Pressure on cylinder walls is caused more by the side force of the piston as it is pushed down in the bore by compression. In used up motors, if you run a dial indicator down the bore, you will see the cylinder "baloon out" a few thousandsth about one and a half inches down from the deck. This "baloon out" cannot be compensated for by the rings at high rpm...therefore oil starts to get into the combustion chamber. The burning of the oil causes the detonation that ruins the engine. This is the reason block guards do not work as well as most people think. The reason the piston starts to push sideways on the way down is because of the angle of the crank as it spins off of top dead center. It naturally trys to push the piston sideways. Longer rods help to control this side force a little.
If anyone feels different about what I just posted, I would love to hear from you!
Earl
Earl
New User
Re: Is it boost or horse power that ruins engines? (earl)
Would it help if the block guard was pushed down an inch and a half or so instead of at the top? So you guys dont think the girdle would be of any advantage to me. Ive heard that Z10 products are almost impossable to obtain is there any truth to this?
Even though I don't like them, I would install the girdle just as the mfg. says to do it. IMO Honda had a reason for building an open deck motor and I think they could have made it closed if they thought that worked better. Only an opinion.
I dunno, seeing how golden eagle sleeves are I dont get why honda didnt make their sleeves similar to that. Stock open deck sleeve just suck with turbos
New User
agreed but why not use make honda engine closed deck? what advantages do open deck have over closed deck?
jDMJeRk
11-08-2004 05:01 PM
