greddy turbo kit on 98 civic ex....how much for kit and install???
New User
i need to know how much in total will i need to speed to run everything efficiently with stock/low boost on a greddy 92-95 civic ex turbo kit plus install on a 98 civic ex???.......i am hearing in the range of about $2000. what kind of stuff do i need to do for my civic to handle this? also, if i get a boost controller, can i set it at 0psi when i dont need the boost and set it back to about stock....5psi when i need to at will at a light?
New User
Re: greddy turbo kit on 98 civic ex....how much for kit and install??? (hobo79)
also wanted to know whether it is realistic to get high 11s with a greddy with high boost and upgrades?
New User
Greddy's kit is only good because of the electronics it comes with and that won't go into your 98 without alot of work. If you want Greddy wait for the 96-00 kit that should be out by the end of the year or so. IMO i would say go with Drag 3 and run 7 psi. That is reliable and gives you a push in ya ***
Re: greddy turbo kit on 98 civic ex....how much for kit and install??? (vtec-nut)
High 11s with a Greddy turbo kit i don't think its possible should go with a bigger turbo Drag, Rev, F-Max.
[Modified by IgniteTeg, 12:25 AM 8/22/2001]
Superdragr45
01-24-2004 11:02 AM
hobo79
10-20-2001 10:32 AM
