Drag Gen 3 flaws?
Old Aug 23, 2001 | 05:00 PM
teamrocket si's Avatar
Default Drag Gen 3 flaws?
What are the flaws in the drag kit? I know the wastegate needs to be replaced but other than that are there any other inherent flaws with the kit? Also can you get the kit with a tial wastegate, instead of whatever it comes with?
Old Aug 23, 2001 | 07:13 PM
Ray's Avatar
Ray
New User
Default Re: Drag Gen 3 flaws? (teamrocket si)
is the deltagate really that bad? Maybe cause im using a boost controller but it seems to work fine for me.
Old Aug 23, 2001 | 07:18 PM
JaEz's Avatar
New User
Default Re: Drag Gen 3 flaws? (Ray)
i dont know about its flaws becuase i dont have mine installed yet, but i did ditch the wastegate and the fuel pump for the tial and a bosch. i also got rid of the check valves and the fmu because im getting hondata also, but if your not planning on boosting very high then that wont really be necessary
jase
Old Aug 23, 2001 | 07:39 PM
DIRep972's Avatar
Smarter than you
the wastegate is a good idea, and get a steel braided oil return line...
Old Aug 23, 2001 | 09:10 PM
Mikex25's Avatar
New User
Default Re: Drag Gen 3 flaws? (DIRep972)
Where do you get steel braided oil return lines from? When you get them is there anything else you need to buy?
Old Aug 23, 2001 | 09:14 PM
dustin's Avatar
Default Re: Drag Gen 3 flaws? (Mikex25)
http://www.bakerprecision.com
you also need to get some Earls fittings to connect the oil return from the turbo to the oil pan. I used -10an hose/fittings.
Dustin
Old Aug 23, 2001 | 09:32 PM
TypeC's Avatar
Default Re: Drag Gen 3 flaws? (dustin)
What about the DP? I heard that it has no flange or it doesn't reach the cat. These are all rumors, so be kind. -C
Old Aug 23, 2001 | 09:36 PM
dustin's Avatar
Default Re: Drag Gen 3 flaws? (TypeC)
It is long enough to reach the cat, but you would want some flexpipe anyways or you'll probably crack the manifold.
It has no flange, I used a $5 exhaust repair kit from autozone as flexpipe and had a small flange->3" of piping adapter made at an exhaust shop for $30. Has worked for me so far (almost a year turbo).
Dustin
Old Aug 23, 2001 | 09:37 PM
Arturbo's Avatar
Better than steak
25 Year Member
You are correct calvin. The downpipe does not have a flange to bolt up to the cat. The reason they do this is because most people dont use cats. If you need one with a flange I can get one made for you because my fabricator is in San Antonio that makes the downpipes for me.
art
TypeC's Avatar
Wow, that was fast. Got any pics? -C
Old Sep 10, 2001 | 06:09 AM
Mr. Vapor's Avatar
Hey guys, i am anxiiously awaiting my Drag 3 from ben.....3 weeks now (oh well) anyways i thought it would be a good idea to bring this back since many people are involved in the group buy! any one else have any input
Espeically Art, could you elaborate on the lack of flange and cat deal. i need to get this resolved and seek your advice! hope you reply man!
Old Sep 10, 2001 | 11:29 AM
IgniteTeg's Avatar
Default Re: Drag Gen 3 flaws? (NYb16)
Art btw do you have a good dp for 3" bolts on to the cat and turbo manifold? Or the Drag III dp is good???? How many inch does the Drag III dp comes with?? Any pix how much is it and cost to shipped to San Diego and stuff? Thanks for your help.
k9n
Nov 12, 2005 09:22 AM
biassj
Mar 18, 2004 10:49 AM
350z-tech
Oct 17, 2001 08:54 PM
tsjag17
Jul 22, 2001 06:11 PM
