Will these Injectors fit my Teg?
I've recently come across a set of RC 310's for a 92-95 civic. I drive a 99 integra LS (with drag kit if it matters) . The seller says that they will fit integras, only obd1 one's however. In fact..here's a copy and paste of an e-mail he sent me.
"I found out the injectors are actually made for 92-95 Civics and 94-95 Integras (obd1 cars), but it sounds like your connectors would fit, which is rather strange because nobody elses I've talked to would. For them to fit into my type-r intake manifold, I just slipped the rubber donut gasket around the lower portion of the injector and slid them in. "
Now is it worth it to save a few bucks and see if all I have to do is buy an obd2 injector clip, or should I just buy a set made for my car?
Thanks,
Cole
Thanks,
Cole
Re: Will these Injectors fit my Teg? (PureTeg420)
Ya even cheaper than buying the clips from RC, is to cut he injector clips off a 92-95 civic harness, then cut your stock injectors clips off and solder on the new ones.
092eg6
12-23-2009 01:38 PM
Acura_I-RS
03-09-2003 09:57 PM
