Can Hondata control 700+ cc injectors?
Re: Can Hondata control 700+ cc injectors? (sleepy)
As long as they're saturated, right? You have to run the right ECU to run Peak and Hold injectors.
I've heard of people on this board running 750's that idled just fine. You should ask on the Hondata forum. It's part of the TOO BBS at http://www.theoldone.com
Re: Can Hondata control 700+ cc injectors? (Inlinefour)
i heard the 750cc is the max limit currently. I dont think it can contorl the larger 860cc or 1000cc injectors. that are needed for the ultra high hp
New User
Re: Can Hondata control 700+ cc injectors? (DirtyLude)
they can be Peak and Hold as long as you have a Resistor Box, i'm thinking about going 720cc with my hondata
[Modified by JaEz, 6:39 PM 8/29/2001]
On a side note, can the Hondata control "8" injectors? 700 seems like a huge a$$ injector to be running for ONLY 350 whp. Wouldn't it be wiser to run 8 "smaller" injectors, and have the second fuel rail on when there's more boost. This would be for a "street" car of course where fuel efficiency is somewhat of a concern, drag cars don't count.
Re: Can Hondata control 700+ cc injectors? (JaEz)
I am going with 720 cc and a Hondata re-program. If you look at Hondata's website. They will give you suggested injector size for the amount of HP you want to produce. The reason why they suggest bigger injectors is the fuel pressure is only at 60 psi. That why you aren't overtaxing the fuel lines and the entire injection system! If you are only going with 350 whp I would suggest the 550 cc, but of course it is up to you. Contact your nearest Hondata dealership and they will be happy to help you.
By the way, I am thinking of getting a groupbuy together to see if RC will cut us a deal. Let me know if you would be interested.
gsr*lude
gsr*lude
