wastegate acuator problem..please help
Old Aug 23, 2001 | 10:31 PM
jmad08's Avatar
New User
Default wastegate acuator problem..please help
i have a custom T25 that is only boosting 5psi the most. i tried to use my TURBO XS boost controller to turn it up but nothing happens. i think it may be the rod on the acuator because i think my friend modified it so that it can only maintain 5psi. i think he bent the rod, but maybe this has caused the door to be opened a bit so that the boost leaks out? i have to rev the turbo from 3,000-6,000 to get full boost. i can get a new acuator but it will be set at 14psi since it's from a stock 2nd Gen Eclipse. i there a way i can make it boost only 5psi without bending the rod so the door will remain closed and boost quicker? thanks
Old Aug 23, 2001 | 10:41 PM
93LSivic's Avatar
Default Re: wastegate acuator problem..please help (jmad08)
I belive that you can thread the rod so that you can actually use it as a boost controller. I have the web addy somewhere that shows how to do it, if I can find it I will post. Also if you need the actuator, I have one from a 2G DSM's T25.
motormike40
Jan 3, 2007 02:35 AM
zseeanz
Nov 9, 2003 06:04 PM
onePOINTsix
Aug 19, 2003 10:59 AM
stockgreencivic
Apr 10, 2003 07:32 PM
cjames235
Aug 23, 2002 11:02 AM
