HElp with turbo street setup?
Old Aug 18, 2001 | 06:19 PM
Trajic's Avatar
New User
Default HElp with turbo street setup?
What do you guys think I should get for a good street setup? I wanna boost like 12-13psi.
9.0-1 forged pistons is that to low for street car or should i got for 9.5-1
forged rods
skunk 2 manifold
drag gen 3 turbo kit
Ignition upgrade
Fuel Upgrade
CM stage 3 clutch
Apex vtech controller
Apex boost controller
Apex turbo timer
What size injector should i use
and what kinda times do u think i could get with this setup.
[Modified by Trajic, 3:20 AM 8/19/2001]
Old Aug 18, 2001 | 08:13 PM
Blown90hatcH's Avatar
Default Re: HElp with turbo street setup? (Trajic)
12-13 psi....just get an Inline performance headgasket..... and dont worry about the block. Then get all the other stuff you have listed. The inline heady will drop your compr one full point. Run some 370cc injectors....times depend on car and motor.
Jason
Old Aug 19, 2001 | 12:08 AM
DIRep972's Avatar
Smarter than you
what kinda car is this going in? and on what motor? u will want to go standalone if u r running over 10psi..
Old Aug 19, 2001 | 03:55 AM
IgniteTeg's Avatar
Default Re: HElp with turbo street setup? (DIRep972)
Is the Vtec controller necessary for turbocharged applications?????? How about cams?? Does it need to be upgraded or the stock one will work fine and last long?? Reliable?? Thanks for the help.
Old Aug 19, 2001 | 09:02 AM
Default Re: HElp with turbo street setup? (IgniteTeg)
Keep the stock gsr cams. For the money cams are not worth it. Get a VAFC to tune the car with bigger injectors and also you can move your Vtec point with that.
Jason
Old Aug 19, 2001 | 11:50 AM
FAST94GSR's Avatar
New User
Default Re: HElp with turbo street setup? (Blown90hatcH)
You may want to use a Hondata. There's no substiute for insurance like pistons and rods. That should make for a fun street car. 12's no problem.
Old Aug 19, 2001 | 01:57 PM
jinxproof99's Avatar
New User
buy 440 injectors
buy apex super afc
buy clutchmasters stage 4
buy inline pro headgasket for 20lbs of boost on a gsr motor w/race gas
run 11's
Old Aug 19, 2001 | 11:43 PM
IgniteTeg's Avatar
Default Re: HElp with turbo street setup? (jinxproof99)
okay so Is the Apexi Vafc vtec controller needed for turbocharge cars???
Old Aug 20, 2001 | 06:54 AM
JaEz's Avatar
New User
ignite: if your getting a standalone then you wont need the VAFC
gosu08
Mar 2, 2008 03:38 AM
TnC99si
Jun 29, 2005 09:29 PM
TeamCracka
Feb 16, 2004 07:30 AM
mrcivicsi2k
Jun 23, 2003 08:50 PM
V8killa1.8
Nov 6, 2002 09:07 AM
