7psi limit revisted...
Old Aug 21, 2001 | 10:18 AM
redline's Avatar
Default 7psi limit revisited...
I have triple checked everything now and still the same thing.
I was talking to another turbo honda owner over the weekend and he had an avc-r etc.. and he said the avc-r would not allow you to boost past double the wastegate spring and that he had the same problem as me and he fixed it by buying a bigger spring? Anyone else here of this? Should i spend the money on a new spring?
k
[Modified by redline, 12:18 PM 8/21/2001]
Old Aug 21, 2001 | 11:04 AM
Purelude's Avatar
Default Re: 7psi limit revisited... (redline)
my spring is rated at 4.4 psi and i've boosted to 10psi before w/ the avcr
[Modified by Purelude, 12:05 PM 8/21/2001]
Old Aug 21, 2001 | 11:08 AM
dustin's Avatar
What solenoid duty cycle is your AVC-R peaking at? If it is below 100%, then something else is wrong.
What do you have the start duty cycle set to?
Dustin
Old Aug 21, 2001 | 05:06 PM
SIK IN DA HED's Avatar
New User
Default Re: 7psi limit revisited... (dustin)
exactly why i dont want a boost controller... too much bullshiet tryin to work it.
Old Aug 21, 2001 | 08:10 PM
redline's Avatar
Default Re: 7psi limit revisited... (dlplayboy)
well hopfully once it is all worked out it is a crazy thing!
I was in bed sick today but i had to go to the store to get some drugs and played with the boost controller.
My starting settings
Boost set at .55 kg/cm2
duty at 50%
Start duty 0%
peak boost .51kg/cm2 max duty cycle in the 40% range
boost set at .55 kg/cm2
duty at 30%
start duty at 39%
peak boost .66 kg/cm2 max duty cycle at 73%
So i think that the start duty cycle was the problem or part of it?
k
91integraLSVTEC
Oct 21, 2009 11:09 AM
*Boostwerks*
Apr 3, 2005 05:55 PM
92jdmhatch
May 4, 2004 12:10 AM
I Gotta Question
Jan 18, 2004 12:41 PM
hybrid901
May 2, 2003 02:49 PM
