Ignition advance + turbo
Old Aug 21, 2001 | 03:39 PM
dustin's Avatar
Default Ignition advance + turbo
I have been thinking about how the stock ECU runs lots of timing advance in high rpms on the GSR (not as much time for the combustion event, but the fuel takes the same amount of time to burn). The tables are pretty aggressive.
Is it safe to run no progressive boost retard @ 7psi? My timing is at 14deg BTDC and I see no real signs of detonation (car acted funny once and got a bit of detonation that could be seen on the plugs, but I have not seen any since). It just seems that it is not a really good idea.
With 91 octane fuel, what does the ignition table look like for high boost (12psi+) on a GSR in high rpms for say a hondata tuned car? Is it drastically retarded?
Just curious.
Dustin
Old Aug 21, 2001 | 04:01 PM
LsTurbo91's Avatar
Default Re: Ignition advance + turbo (dustin)
Here's a post about that with a hondata ignition map. It doesn't look like its retarded very much.
https://honda-tech.com/zerothread?id=50353
Old Aug 21, 2001 | 11:12 PM
dustin's Avatar
Default Re: Ignition advance + turbo (9psiLsT)
Good information. Hmm.....
Dustin
Old Aug 22, 2001 | 06:29 AM
Seraph0's Avatar
Awesome.
Adriano
Jun 28, 2003 07:55 PM
ClubSiRacer
Apr 15, 2003 07:04 PM
echo999
Jan 13, 2003 12:28 PM
echo999
Jan 3, 2003 12:27 PM
PrecisionH23a
Aug 31, 2002 09:51 PM
