NOS
Old Aug 27, 2001 | 07:53 AM
GSRacer's Avatar
New User
Default NOS
Does anyone in this board run direct port or the plate system on their GSR??? If so... what issues did u come accross? What did u have to do?? What's a good setup??
Old Aug 27, 2001 | 08:41 AM
GSRwBOOST's Avatar
Default Re: NOS (GSRacer)
there are several of us taht have had the plate system and i know one person that had a direct port.
my gsr used the plate kit.. hell the plate is still in the car for future use... and the only issues i came up wiht were adjusting the timing for a clean run and upping the fuel pressure tocompensate for the plate... ohter than that, it worked great!!!
Suggestions are to get a header and exhaust to relieve the pressure created.. an fpr to up the fuel pressure a little and retard the timing a couple degrees...
I only ran the 75shot for a year, then went turbo...
Old Aug 27, 2001 | 09:33 AM
GSRacer's Avatar
New User
Default Re: NOS (GSRwBOOST)
yeah, i have a fpr, header, cat-back, and msd. I wanted to know if i needed any fuel mods (ex. pump, injectors, etc.). I was hopping to run 100 shot.
Old Aug 27, 2001 | 10:38 AM
GSRacer's Avatar
New User
i just got off the phone wit nos... and they said that i would need a 255 intank fuel pump and a block girdle. What's a block girdle??? How much does it cost?? Is it worth it?? thanks in advance
Old Aug 27, 2001 | 11:06 AM
riot's Avatar
issues?
Honestly, there are no issues. Just make sure you do your research.
Deffinetly get new plugs (two steps colder) NGK-BKR7E work great. Also...a Walbro 255lph fuel pump will work great. That about all that you may need for the BASICS.
If you want to cover your *** completely, there are many other pieces to the puzzle.
-ryan
RICE POLICE SIP
May 19, 2005 01:42 PM
mischiefinnovations
Sep 19, 2004 09:45 PM
vteec
Apr 11, 2004 08:06 PM
SCHYBRID
Mar 6, 2002 08:13 AM
