Hooking up first gen J&S
Cliff is almost done with his turbo install, and needs to know the following:
Where is the TPS sensor and which wire does he tap into?
Which wires are the O2 sensor and O2 sensor ground, and which one (upper or cat) does he use?
Doin' Cliffs dirty work huh Pat!
I know the O2 wire for our car is on the C connector(31 P) on the ECU, terminal #16. Should be solid white. Not sure which is the ground. Couldn't he use any ground source though!
For others attemping to offer some help, this is a '00 ITR. Thanks.
Drinker
