Another "how fast" question, look please tho.
My setup up now.
88 CRX HF(1800 lbs)
91 B18A w/ 95 B18B cams
JDM S1 tranny
I/H/E
MSD ignition, wires, etc.....
In a month or so:
T3/T04b 60-1 turbo
starion I/C
HKS SS BOV
Deltagate wastegate
Portmatched Revhard manifold
450cc GST injectors
ZDYNE ECU
running 8~10 lbs of boost
Now after all the "stuff" being put on. How quick do you think my little sleeper will be? Seeing as how i'll be running a ZDYEN, I shouldn't have any problem running 10 PSI should I? Anyways lemme know what you guys think.....
~steven
88 CRX HF(1800 lbs)
JDM S1 tranny
I/H/E
In a month or so:
T3/T04b 60-1 turbo
starion I/C
HKS SS BOV
Deltagate wastegate
450cc GST injectors
ZDYNE ECU
~steven
Re: Another "how fast" question, look please tho. (Speed PHreak)
actually, there's a guy in town that running a fully built b16 turbocharged with a zdyne gold and he said it sucks. I think it's the ttuning, but he swears that it sucks. Get this, his best time was a 14.3, other than that, he was running high14's and low15's all day long with trap speeds under 100mph mark.
Why such a large turbo? What are your hp goals? The turbo you're referring to is much larger than the turbos DRAG uses.. or even F-MAX. Also, what size exhaust housing and turbine stage will you be using? If you're going to be using that large of a turbo AND a big exhaust housing (.63 or higher), you should increase your rpms up to 8k atleast.
Re: Another "how fast" question, look please tho. (VaporTrail)
I would ditch the S1, but It's in there now and I like it. Its not a long distnace car, it's toy ya know? Yeah I had a LS tranny, so what...........I don't feel like pulling the motor out, ugh.......ya know what i'm saying?
Re: Another "how fast" question, look please tho. (Rob92SC)
I didn't know that it was that large. My HP goals are only around 225 to 250 for now. I was wanting to go with a staight T3, I've got this guy willing to sell his custom kit off a car almost exactly like mine. I know this is nieve but will that t3/t04b 60-1 suck? I'm mean i'm not looking to run over, 10lbs of boost.........HELP?
New User
It's not a matter of distance driving, but especially with that big turbo on there, you'll have problems spooling it with the ultra short gears of the S1.
Hey.. I know i'm not Honda, but here's what I'm doing:
I'll be using a T04b Super S-3 with T3 .48 exhaust. This will produce roughly 250+whp at under 10psi. Plus it will spool much faster than that 60-1.
**notice** I have a much shorter redline (6.5k) so you might want a larger exhaust housing like a .63 to match your higher redline.
[Modified by Rob92SC, 2:39 PM 8/29/2001]
[Modified by Rob92SC, 2:40 PM 8/29/2001]
whats the deal with the 60-1? I'm not sure what tha is here is the guys site if ya wanna look.
http://www.geocities.com/crxls18
either ur a big bssing poser or ur just plain stupid in getting that size a turbo for ur Si engine...if ur goals were so low and boosting so low and ur low hp goals u woulda been more than happy with the greddy 18G turbo kit.....fast spool ups and max boost levels of 15psi....max output at around 300hp mark
Re: Another "how fast" question, look please tho. (redteg1)
Hey! Look at the top post alittle closer and you'll see thats it's not an Si motor. Jackass.
Re: Another "how fast" question, look please tho. (Slow_ass_4dr)
lol! As far the zdyne sucking, I think not! What do you think Hondata tunes with? Fuel Pulse width same thing as a zdyne. I would think the tuning would be the best part since he doesn't have to have an emulator to change a setting! That guy probably doesn't know how to tune it or drive.
Re: Another "how fast" question, look please tho. (9psiLsT)
What will be the characteristics of a t3/t04b 60-1 turbo? On a LS motor where will it start putting out boost? Should I find another turbo if i'm only looking to run 10 PSI? Will lag be a prob?
