What's the difference running a 35mm or 40mm wastegate?
I'm assuming no difference ...
Just wondering as I'm starting to put together my custom setup.
First on the list is a turbo manifold ... should I get a 35mm or 40mm wastegate port?
Re: What's the difference running a 35mm or 40mm wastegate? (redline)
Yeah, how much do you plan on running? 35mm is good for quite a bit of boost. I think if you plan on going upwards of 20psi the 40mm is a good idea.
Re: What's the difference running a 35mm or 40mm wastegate? (97CivicFerio)
That answers me question. Definately not going over 21 PSI. 35mm wastegate for me!
Re: What's the difference running a 35mm or 40mm wastegate? (BlackGSR)
The 35mm Wastegate will only support 350 whp or so! You may be able to make 400, but the wastegate spring will begin to flutter with excessive boost! The 40mm and 46mm wastegates are usually good for 400-1000 whp!
New User
Re: What's the difference running a 35mm or 40mm wastegate? (TurbochargedSER)
what about the new 35mm high pressure.
best bang for buck
any one have this, it fits on a 35mm flinge but has a 40mm head on it i think.
check into into it
best bang for buck
check into into it
New User
How does the Tial 40mm compare to the HKS racing wastegates? I have a friend planning a high boost WRX buildup who's wondering..
-Xerxes
-Xerxes
Re: What's the difference running a 35mm or 40mm wastegate? (Xerxes)
Tial has a stainless steel housing, HKS uses cast iron. not that I've ever seen a bad HKS wastegate, just noting a difference.
Re: What's the difference running a 35mm or 40mm wastegate? (TurboInteg95)
I´m boosting 1.2 - 1.3 Bar (~20psi) without any problems on mine. Using an AVCR boost controller.
New User
Re: What's the difference running a 35mm or 40mm wastegate? (pkripper)
posted by pkripper:
best bang for buck
check into into it
I have the Tial hybrid 35/40 mm gate. It has a 9lbs spring and can handle 26-28 psi.
best bang for buck
check into into it
Re: What's the difference running a 35mm or 40mm wastegate? (abraunb16)
the tial sport verisons are bad *** units. i used one on a 450 hp car wiht no issues up to 29psi soldi wiht 1.0bar spring and profec b
TurbothisLS
08-29-2002 07:27 PM
