doing away with power steering
just undo all ur power steering ****, no need for a new rack, but be sure to plug the holes
[Modified by 1, 8:02 AM 4/14/2002]
a 1992-95 civic CX rack
thanks...how much shoudl i expect to pay for this?[Modified by downpipe, 9:02 AM 4/14/2002]
[Modified by downpipe, 9:24 AM 4/14/2002]
About $100 bucks at a counter type bone yard, maybe cheaper at a pull-your-part. Make sure the gears are nice and smooth with no restrictions. You will be able to pull and push the rod from end to the other with the rack off the car.
thanks...how much shoudl i expect to pay for this?About $100 bucks at a counter type bone yard, maybe cheaper at a pull-your-part. Make sure the gears are nice and smooth with no restrictions. You will be able to pull and push the rod from end to the other with the rack off the car.
thanks!
i'm converting mine right now. the cx rack cost me 75 bucks, but i had to buy some misc. parts from honda that the yard didn't provide (and most won't.) so all in all it was about 100 bucks. it was a fairly easy conversion (granted there's no engine in the car at the moment.) the hardest part was getting the rack aligned with the steering wheel... which took quite a few tries.
Also, the rack may be smaller in diameter so you may have to use larger rubber sleeves on the passenger side mounting point.
he probably needed a larger splined U-joint that connects rack to column. I hate lokking for them and need another right now, if someone has one for sale you get 20bucks from me plus shipping.
Paul Bisioc
Jun 25, 2019 11:29 AM
dELfONiK
Mar 9, 2007 12:14 PM
Jap Ek9
Mar 22, 2004 03:11 PM
