search isnt working now guys, how do i adjust bov?
New User
im just trying to make sure my turbo is running right cause my times were bad. they are in another post. so i'm running 8psi roughly and i was turning the valve to the hard side so boost pressure won't come out. should any air come out at idle, i know it won't becuase the engine is still at vacumm, so should the bov be "sucking" in any air? how do i do it?
Re: search isnt working now guys, how do i adjust bov? (HXMan)
My bov is open when the engine is idling an closes when you hit the accelerater...when you let off the accelerator...it opens...
Re: search isnt working now guys, how do i adjust bov? (MiraiZ)
That is how mine works as well MiraiZ, and I have the same setup as you. I've never messed with around with adjusting it, so I'm also interested in what is normal.
New User
Re: search isnt working now guys, how do i adjust bov? (Brian_92GSR)
damm i just wanna make sure i dont loose boost pressure when im in boost
New User
Re: search isnt working now guys, how do i adjust bov? (clean)
should be closed at idle. if u like it to be open u might as well stick a filter on it. u can suck something in. keep it closed at idle and let the intake filter do the sucking. heh
if u cant see it, stick your finger in there with the car running and tighten until the valve is shut. give it a couple quick revs and double check if its closed.
Re: search isnt working now guys, how do i adjust bov? (Pritos)
So that is the only thing the adjusting bolt does? What's odd if the f-max kit actually came with a filter to go on the BOV.
_Endless_
07-04-2003 10:56 AM
