turbo ls
Old Apr 11, 2002 | 06:33 PM
djay86's Avatar
Default turbo ls
if i turbo an LS is it going to put a big strain on the parts like timing belt etc?.. i would only boost to max 8psi
Old Apr 11, 2002 | 06:34 PM
dustin's Avatar
Default Re: turbo ls (djay86)
oh boy
Old Apr 11, 2002 | 06:39 PM
Prelussion's Avatar
just run a big shot of nawwwws then kid.
Old Apr 11, 2002 | 07:55 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: turbo ls (Prelussion)
The timing belt will actually snap at exactly 9psi....so I'd be careful.
If tuning is perfect, your belt won't snap. I wouldn't be so sure about the radiator tho.
Old Apr 11, 2002 | 08:18 PM
intekragsr's Avatar
turbo got absolutly 0% to do with a timing belt. You might want to worry about the internal parts of the engine.
Old Apr 11, 2002 | 08:19 PM
DIRep972's Avatar
Smarter than you
be careful though, ur air conditioning can break if u run too much boost..
Old Apr 11, 2002 | 08:24 PM
intekragsr's Avatar
Default Re: turbo ls (shamoo)
Damn have you ever seen a radiator cap shoot through the hood? fawkin crazy! Yea dont boost too much above vtec and u are safe
Old Apr 11, 2002 | 08:35 PM
shadowdawn's Avatar
Default Re: turbo ls (intekragsr)
You guys are horrible , don't listen to them, do yourself a favor and search or read this board like crazy to inform yourself.... these guys don't take kindly to newbies (which can be annoying at times) at first...
Old Apr 11, 2002 | 11:51 PM
SIK IN DA HED's Avatar
New User
Default Re: turbo ls (shadowdawn)
it depends... did you install the timing belt correctly? tie each end of the belt to each side of the intercooler. this should hold the intercooler in the proper position so you can boost up to 12lbs safely.
Old Apr 11, 2002 | 11:54 PM
sushibug's Avatar
Default Re: turbo ls (dlplayboy)
i like cheese.
Old Apr 12, 2002 | 03:36 AM
b18b98's Avatar
HAHAHAHA
stevenDAtegra
Apr 24, 2009 07:17 PM
supabang
Jul 31, 2007 05:52 PM
dan's integra
May 25, 2006 12:35 PM
gen2integra2001
May 6, 2005 08:49 PM
