b20+drag turbo kit, have a coupel questions
iv been told a b20 is very similar to a b18b an b18bs go well with turbo , so will a b20 go as good on turbo , what parts whould you ad to a drag kit goin on a b20 in a 97 hatch , i no i get a sunk2/ls intake manifold, now what else whould you ad wihtout doin internal stuf just to make it reliable an safe , how much boost could you run on just that setup an what kinda numbers whould that produce, and whould this be any better than just goin with a b18c1
thanks
an sorry for all the questions
thanks
1 Post
Re: b20+drag turbo kit, have a coupel questions (spizone)
b20 wont help top horsepower numbers, but it will give you more torque. This is what jeff told me at importbuilders.com. If i were u , i would have importbuilders.com built your block and head
Re: b20+drag turbo kit, have a coupel questions (intekragsr)
like what whould ls/b20 motor pull with a drag kit soem 440s hondata 2b fully tuned an runnin i dunno say 10lbs, and what kinda mild internal setup whould be good maybe eagle rods, je 9-1s stainless valves an mayeb a little headwork , anything else
1 Post
i dunno......im a newbie kind of myself, dont want to mislead you and get flamed. Go to importbuilders.com and check out their 2 liter killer turbo block.
Smarter than you
I dont see why it wont give more peak hp? I can understand it not being much different, but the B20 has 9.4:1 compression plus more displacement, I would assume it would make more hp and torque..
1 Post
Re: b20+drag turbo kit, have a coupel questions (DIRep972)
B20 motor should make more hp. The B18B makes 140-142 hp stock. The B20Z stock with the stock LS intake manifold makes around 160. Thats around 10% more hp.
Re: b20+drag turbo kit, have a coupel questions (W.ZeroB18C1T)
is it true that the b20 block is similar to the h-series and f-series block where as you would need to sleeve it if u want to run aftermarket forged pistons like JE? Or are they like the b16 and b18 where you can just intall the pistons on stock sleeves
Re: b20+drag turbo kit, have a coupel questions (greengangsta)
I have a question, is the B18B head a direct bolt up to the b20 block?
what was the setup on this 'stock' b20? i would like to see where i should get started.
thanks
thanks
Re: b20+drag turbo kit, have a coupel questions (irdprelude)
LS Head is the same thing as the B20 Head. I used my LS head on the B20 block. And as for it not holding well over 10 psi, I'm running 16-18 PSI on the stock B20 sleeves with the JE pistons.
Re: b20+drag turbo kit, have a coupel questions (BG Boost)
mind if i ask what kind of #'s you are producing? i am curious to see if this is going to be an engine that i want to stick with, or if i want to toss my car.
thanks
thanks
ZeRo
03-12-2002 11:16 AM
