Timing at 24??!?!
Old Apr 15, 2002 | 04:50 PM
Etylorcen's Avatar
Default Timing at 24??!?!
I was doing a smog pretest today and when they checked the timing it was at 24. I was pretty surprised. I never advanced or retarded the timing so how did this happen? Can the ecu adjust timing itself? Since then I resetted the ecu and I'm going to buy a timing gun tommorow to check it.
Old Apr 15, 2002 | 05:15 PM
SIK IN DA HED's Avatar
New User
Default Re: Timing at 24??!?! (Etylorcen)
ever move or play with the distributor cap? possibly lean on it while tryin to get to a part in the back of the engine bay?
Old Apr 15, 2002 | 05:57 PM
dustin's Avatar
Default Re: Timing at 24??!?! (dlplayboy)
was the motor fully warm and at idle?
Old Apr 15, 2002 | 10:17 PM
PrecisionH23a's Avatar
make sure the engine is in lymph mode when you check your timing. there is a little plug harness under your dash called the service connector i believe. anyways, get a wire and put one end in one side and the other end of the wire in the other. if you dont have this wire in, you will get wrong timing readings.
Old Apr 15, 2002 | 11:43 PM
dustin's Avatar
Default Re: Timing at 24??!?! (GudeH23a)
without jumping the service connector I just get "jumpy" readings for timing... but the timing is usually accurate as long is the motor is warm and the idle is set correctly.
Dustin
Old Apr 15, 2002 | 11:51 PM
93LSivic's Avatar
Default Re: Timing at 24??!?! (dustin)
Also you will want to unplug the idle valve to drop the idle to around 500. This is when you want to set the crank timing to the designated point. You wont have proper timing if you do this above 700 rpm's.
Old Apr 16, 2002 | 12:05 AM
dustin's Avatar
Default Re: Timing at 24??!?! (93LSivic)
The ecu doesn't add any advance until you are above idle. THe hondata site says to do that (idle at 500) but it really isn't necessary.
Dustin
Old Apr 16, 2002 | 10:00 AM
Etylorcen's Avatar
The engine was warmed up and at idle. Ill try connecting hte service connector and trying again.
Old Apr 16, 2002 | 04:13 PM
Etylorcen's Avatar
Oh yeah when I did the pre-test the NO emissions was too high on the 15mph test but fine for hte 25mph test. Do you think it would run cleaner if I set the timing at 16 or 18?
Old Apr 17, 2002 | 10:53 AM
Etylorcen's Avatar
ttt
Old Apr 17, 2002 | 10:58 AM
sgT's Avatar
sgT
"lymph" mode lol
Its not limp mode either, rather it would be diagnostic mode.
Old Apr 17, 2002 | 11:27 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
You are only allowed + or - 3 degrees in the state of California. More than that, it's history.
Old May 26, 2002 | 07:23 PM
GruvyTune's Avatar
New User
you ever try that? every time I ever tried unplugging that connector, the engine idles down to zero
Old May 26, 2002 | 07:30 PM
Flamenco-T's Avatar
Default Re: Timing at 24??!?! (GruvyTune)
hmm it shouldn;t drop to zero...mine stays at about 500 ish rpm...
jeckel7234
Honda CR-V & Element
Mar 6, 2016 07:02 AM
76 camaro car
May 21, 2011 10:25 AM
northemt88
Mar 15, 2008 12:57 AM
matbh22a
Jun 19, 2007 12:15 PM
AnitRiceSuperStar
Feb 18, 2004 09:42 PM
