Anybody with ZEX Kit on a GSR???
I was just wondering which wire you connected the TPS too from the management box? Is it one of the 3 wires coming off of the harness that is directly on top of throttle body, and if so which color is it? Also do you connect the intake hose from the management box to the plenum that is on the right side of the intake manifold and the fuel pressure hose to the FPR on the right side of the fuel rail? And one last question, do you then tap into those hoses and reconnect the stop hoses or do you just leave them disconnected? Sorry for the length of this post but I want to make sure that I install this correctly. Thanks for any information.
Re: Anybody with ZEX Kit on a GSR??? (White97Teg)
You want the black/red wire that is on the harness between the TB and firewall. As for the hoses, you have one hose that connects the intake manifold to the FPR. This hose is replaced by the 2 hoses with the zex kit. Intake goes to the vacuum fitting on the intake, and FPR hose goes to the vacuum side of the FPR.
[Modified by dubster99, 11:46 PM 4/15/2002]
Full Race A6
08-01-2004 09:08 PM
