How many PSI??
Old Apr 11, 2002 | 12:04 PM
1RMDave's Avatar
Default How many PSI??
Hey, just wondering how many Psi i would be good for with a fully built b16 with 440 inj. and Hondata 3b? only thing is the block hasn't be resleeved. Also what kinda HP numbers would it give with say 14-16 psi??? Thanks
Old Apr 11, 2002 | 12:54 PM
Xerxes's Avatar
New User
Default Re: How many PSI?? (OneStunna)
you're gonna have trouble supplying enough fuel for more than 10-12 psi with only 440cc injectors..
-Xerxes
Old Apr 11, 2002 | 01:11 PM
1RMDave's Avatar
I was thinking that might be a problem, how bout 550's???
Old Apr 11, 2002 | 06:39 PM
PrecisionH23a's Avatar
550cc's would be nice with the hondata. I really recommend resleeving the block, there is only a certain amount of pressure your stock sleeves can withstand until they crack. If you arent planning on resleeving, then tuning is going to play a huge key with your motor. I wouldnt go above 12psi without resleeving, 14 might be pushing it unless you have everything PERFECTLY tuned.
Old Apr 11, 2002 | 07:53 PM
1RMDave's Avatar
Default Re: How many PSI?? (GudeH23a)
Ok, so lets say that i use Darton Sleeves, and JE pistons, eagle rods, Hondata 3B, 550 injectors. would i be able to do 16 psi daily driven????and say if i wanted to go to like 18-20 psi, could i just get say 720 injectors and still be safe, daily driven????
Old Apr 11, 2002 | 08:19 PM
b18cTurbo's Avatar
im boosting 16 psi on stock sleeve whit a block guard
no prob yet
Old Apr 11, 2002 | 08:22 PM
intekragsr's Avatar
why dont u get a block from importbuilders.com?
Old Apr 11, 2002 | 11:56 PM
SIK IN DA HED's Avatar
New User
Default Re: How many PSI?? (intekragsr)
they charge a grip $$$$!
Old Apr 12, 2002 | 12:12 AM
yes, given that you are properly DYNO TUNED but the hondata stage 4b would be even better then the 3b.
22psicrx
Feb 15, 2006 11:22 PM
JDM_EH2
Jun 18, 2003 07:45 PM
justmotor13
Jan 28, 2003 05:24 PM
SpeedMonkeyRacing
Nov 15, 2001 05:51 AM
The Punisher
Aug 26, 2001 07:46 PM
