JRSC people!!
Old Apr 12, 2002 | 01:09 PM
KooK's Avatar
Mustang Sally
Default JRSC people!!
What were your best tq. and hp. numbers? I'm just wondering because I still dont know if a supercharger or turbo is right for me.
Old Apr 12, 2002 | 02:00 PM
csufweed's Avatar
Default Re: JRSC people!! (Tapeworm)
hondata... where you at man? i think you can handle this question...
i've never dyno'd my car, but its pretty darn quick... 13.9@101mph JRSC on an LS Automatic.
Old Apr 12, 2002 | 04:35 PM
Sonny's Avatar
My B16A pulled 212whp/142 wtq at 8 psi on the stock drinking straw exhaust. My previous best with the worthless piece of **** fuel management that you get from JR was 172 whp at 6psi.
Hondata really brought out the potential of this kit.
FMU's and IAT hacks =
Sonny
Old Apr 12, 2002 | 04:47 PM
BHSCGSR's Avatar
Dont know HP - but 12.81@108 is my best.
9psi gsr full interior.
[Modified by BHSCGSR, 1:49 AM 4/13/2002]
Old Apr 12, 2002 | 04:59 PM
2kbill's Avatar
Default Re: JRSC people!! (BHSCGSR)
Mine is on the low end of average for 6psi GSR's whp. Many are around 220, but I'm tuned very conservatively (fuel and timing). TQ is avg, too.
Old Apr 12, 2002 | 05:32 PM
PhxK20a3's Avatar
Default Re: JRSC people!! (2kbill)
219/146,stock ecu,only things i had to tune were the FMU,MSD BTM,and The actual timing from the dis.Car drove like stock for 30K,with good AF readouts on the dyno.I didnt need no stinkin engine management 8.5psi....Could never get a clean run in the car,mits best was 13.5 ,letting off the gas bout 100 feet before the traps,so i didnt hit 5th gear(for those who are curious,i had to hit 5th,i was on 20.6.14 MT slicks,and they sucked *** for what i was doing)
Old Apr 12, 2002 | 07:01 PM
csufweed's Avatar
Default Re: JRSC people!! (Sonnyballs)
Sonny
impressive...
Old Apr 12, 2002 | 08:16 PM
ronin's Avatar
Default Re: JRSC people!! (csufweed)
i pulled close to 200hp, and tq was about 165 on my ls, and tq was over 150 from 3k all the way to 7k. slippling clutch, no traction, bad launches. i get 13.8 @ 102
and of course, i run hondata, number 165. doug might be adding me to his charts
Old Apr 12, 2002 | 10:22 PM
fastfour's Avatar
Default Re: JRSC people!! (ronin)
172/138 on internally stock LS motor w/ 6psi. Best 1/4 is 14.7 at 96 (or 98, can't remember) w/ a horrid 2.4 60ft. I can't launch worth a damn
Old Apr 12, 2002 | 11:11 PM
civicracer125's Avatar
New User
dude will you list your mods that is a good time slip.
Old Apr 12, 2002 | 11:12 PM
dragnGSR's Avatar
This is from when I was SC'd
[Modified by dragnGSR, 12:12 AM 4/13/2002]
Old Apr 12, 2002 | 11:42 PM
Sonny's Avatar
Here's my chart for the curious:
Sonny
Old Apr 13, 2002 | 11:33 AM
KooK's Avatar
Mustang Sally
Whats the MAX PSI that you can get from a JRSC? I'm going to rebuild my engine and harden the internals so it can take higher amounts of PSI. Thanks again and Thanks for all the replies!
Old Apr 13, 2002 | 11:41 AM
csufweed's Avatar
max psi on the JRSC... "they" recommend 10psi max without work... EDYN can "rework" the JRSC to handle like 30psi and push 400hp. BUT the verdict on its validity is still out, however I know of a few who never got their product or money back from this! i've heard of many people running 12psi with no problems... only concern is heatsoak, which also leads to detonation.
Old Apr 13, 2002 | 03:29 PM
BHSCGSR's Avatar
Default Re: JRSC people!! (civicracer125)
To: civicracer125 mods are:
94GSR JRSC with ENDYN stepper pulley. J & S Safeguard timing at 14deg.RC310 injectors and cartech FMU (need Hondata). ITR Exhaust Cam and GSR Intake Cam. Skunk2 gears - intake at 0 exhaust retarded 3 to decrease overlap. ITR springs and lost motion. Crower titainum retainers. Kamikazi header. 3" Thermal Exhaust. MSD6a and blaster coil. Moroso crankcase breather to atmosphere (helps with detonation - no hot oily air going back into the engine. Rev limiter moved to 9200rpm. AEM CAI - going to icebox soon or custom. The 12.81 was run on 8" slicks......
[Modified by BHSCGSR, 12:34 AM 4/14/2002]
Old Apr 13, 2002 | 05:22 PM
ronin's Avatar
talk to overboost.com if you want max boost from your jrsc. its expensive, but scott c. quoted some impressive numbers on a gsr they did.
1_SC_GSR
Jun 14, 2006 05:06 PM
Bimmerman
Dec 10, 2005 11:22 PM
SavEM1
Nov 14, 2005 11:14 PM
stockegsix
Sep 6, 2004 06:06 PM
bigphatcrap
Jun 28, 2002 03:18 PM
