How bad is runing a turbo on stock block?
I was curious.. to see how bad it is to run turbo on a stock ls/vtec block..
Stock as i mean.. pretty much oem internals...*assuming its built correctly*
i know tuning is the key.. but is there harm done by runing a turbo.. of oh ummm 5-7 psi on a stock block? b18b + b16a2 head...
Re: How bad is runing a turbo on stock block? (AzN_Flava)
It runs great, a guy on clubsi.com says that our engines are designed for boost. You should be safe to at least 60psi.
1 Post
Re: How bad is runing a turbo on stock block? (philo)
it was 70psi but ill forgive you
1 Post
Re: How bad is runing a turbo on stock block? (turbocoupe)
Your fine up to 7psi. 10psi is OK but not daily, at the track go for it.
Depends on your elevation.
Typicaly you can boost 2 more PSI for every 3000 ft above sea level.
I would say 8psi is safe for sea level, asumming eng. man. is taken care of.
[Modified by Bryson, 10:54 AM 4/13/2002]
New User
Re: How bad is runing a turbo on stock block? (Bryson)
my kit comes 7.5 out of the box for my b18c1. im guessing its ok if GReddy says so =P I don't punch it much, I rarely get her out of vaccume. Only when im passing someone on the highway, or when im feeling saucy do i punch it.
New User
Re: How bad is runing a turbo on stock block? (Aeka GSR)
just boost the damn thing already.
id say... no more than 9... but i would keep it between 5-7lbs to be on the safe side.
What is this crap?
lets see. higher elevation = less ambient air pressure, means the turbo has to work harder to maintain a given boost pressure = more heat - and youre saying its safer to boost more in thinner air?
whyzat?
Re: How bad is runing a turbo on stock block? (intekragsr)
hmmm what if the 10 psi is tuned with a dyno and wideband using hondata 2b? I was planning on running 9 daily. Please let me know before my dreams are shattered.
Yes 9-10 psi on a TUNED engine is OK. If you just slap on a kit and go I wouldn't run 10psi. Tuning is a must.
I have run kits 12psi with thick head gasket good tuning on a stock b16a block, they all have gone at least 40k no problem. Haven't blown one yet. Ooh yet (knockonwood) so your fine.. just tune
Re: How bad is runing a turbo on stock block? (falconGSR)
here we go....
The quote of "2 PSI per 3000 ft elevation" is NOT an actual mathmatical finding. It is just my experience with what I have seen.
I know of a Guy who boosted a ZC at 14psi for 3 years, with just a hi-pressure fuel pump, 12:1 FMU, and MSD BTM, at an elevation of 4000 ft. He sold the car, so that is why I only said 3 years. The car was also daily driven.
I personaly run 12psi daily, on my interally stock ZC, and have had NO problems.
Then I have heard so many stories of people around sealeval blowing their motors at only 6 psi, with the same setup.
BTW... 10psi at sea level is nothing like 10psi at 4000 ft. The 2 air combinations, have totaly different O2 contents, and there-fore at higher elevations you can boost higher. I'm not saying that YOU SHOULD boost higher, but THERE IS a difference in the maximum safely ran boost level.
I never said it's "safer" then boosting at higher elevations; I'm saying it's "safe" to boost a little "higher" then what the same setup can at sealevel.
porofek
03-08-2019 01:43 PM
