ENGINE REBUILD: GSR or LS oil pump??
I am building a b18b, should i use the GSR oil pump or an LS oil pump? I have heard it is better to use the GSR, but my LS pump is fine, only 18K miles. Thanks,
Re: ENGINE REBUILD: GSR or LS oil pump?? (SEFI8LOxCivic)
how about aftermarket pumps?
silly question but where is the oil pump located.........thats one thing i havent gotten changed.
[Modified by int3gra, 12:05 AM 4/13/2002]
Re: ENGINE REBUILD: GSR or LS oil pump?? (int3gra)
Actually you should go with a type R or B20b oil pump. There the same pumps but flow more. You could use your stock pump with a new gasket, but since you will be sleeving(from your last post) to 84.5mm??, then I would go with the type R or B20. It should run you around $89? If i remember correctly.
