Maximum fuel pressure....
Old Apr 14, 2002 | 12:03 AM
ludelvr's Avatar
Default Maximum fuel pressure....
Hey guys, what's the max fuel pressure that my stock 94 VTEC fuel pump can provide? I've heard a bit over 100. Can anyone verify this please! Would it be possible to run 7 psi of boost and only use an 8:1 FMU? Thanks
Old Apr 14, 2002 | 12:07 AM
b16ahybrid's Avatar
Default Re: Maximum fuel pressure.... (ludelvr)
Ok the stock fuel pump is good for only about 75psi max.
Now are you planing to run stock injectors and a 8:1 fmu? because you will need at least a 10:1 otherwise you will run to lean.
I honestly wouldn't run more then 4psi if you plan to use a stock pump.Upgrade it is cheap insurance.
Old Apr 14, 2002 | 12:21 AM
Sonny's Avatar
The B series pumps have an interal bypass valve that will limit them from flowing above 75 psi:
Do not attempt to boost on the stock pump unless you are running engine management (like Hondata) and big injectors (at least 440cc or more).
Sonny
TEG777
May 17, 2005 12:22 PM
prelittlelude
Jun 12, 2003 10:46 AM
ludelvr
Apr 14, 2003 11:58 AM
ludelvr
Apr 14, 2003 09:47 AM
ludelvr
Dec 19, 2001 07:50 AM
