Milling and decking??
Old Apr 14, 2002 | 09:09 PM
Gmedalion's Avatar
Default Milling and decking??
What are the benefits to doing this to your head (milling) and block (decking)???
Old Apr 14, 2002 | 09:11 PM
bigTom's Avatar
Default Re: Milling and decking?? (Gmedalion)
it yields slightly higher comp when u do it
people also do it to make sure the surface is straight
Old Apr 15, 2002 | 08:18 AM
Gmedalion's Avatar
Default Re: Milling and decking?? (ek9t)
How do you know if the head needs milling or if the block needs decking??
Old Apr 15, 2002 | 08:28 AM
rtype11's Avatar
milling and decking are basically the same operation, i think I can clear it up as follows, one you do to "service" the head that may be bowed or crooked to ensure a tight seal, the other is done in order to increase CR. there is a little nobby cut out that shows the service limit for decking, milling etc to ensure that psitons wont hit valves with stock cam shaft.
Old Apr 15, 2002 | 08:31 AM
int3gra's Avatar
Default Re: Milling and decking?? (rtype11)
do u do this when sleeving the block?
Old Apr 15, 2002 | 08:38 AM
VTC_CiViC's Avatar
Default Re: Milling and decking?? (int3gra)
Generally, when a block is serviced (such as sleeving etc..), is it decked as a precaution to ensure it is perfectly flat.
Old Apr 15, 2002 | 09:04 AM
X2BOARD's Avatar
Default Re: Milling and decking?? (VTC_CiViC)
Keep in mind that milling is irreversable and may change the angle at which the valve faces the relief on the piston. (Generally not a good way to increase CR if it can be avoided)
BoldFart16
25
Feb 20, 2011 04:42 PM
sivtechatchy
Mar 6, 2009 03:45 AM
ITRnorway
Nov 16, 2006 01:54 PM
jspec-integ Ls
Nov 15, 2005 04:26 PM
