turbo question
Old Apr 14, 2002 | 07:30 PM
sweettooth's Avatar
Default turbo question
need a good turbo for a b16. Should I get T3,T3/04B or E. Basically I need a turbo that will give me a good power curve both mid and high end. Right now I am looking for about 15psi. I have an ACT clutch and JUN ultralight flywheel with a Quaife LSD. Will this setup hold 15psi with a block guard and Ross 9.5:1 pistons and eagle rods and a good fuel setup.
Old Apr 14, 2002 | 07:36 PM
TurboSedan's Avatar
New User
Default Re: turbo question (sweettooth)
If you want decent low end, the T3 Super 60 works well on your engine. Another good choice would be the T04E 46 trim, but that one would have a little more lag and better top-end power. 15Psi should not be a problem with the built bottom end and 9.5:1 pistons. Good luck with whatever you decide to do!
Old Apr 14, 2002 | 07:40 PM
sweettooth's Avatar
Default Re: turbo question (97CivicFerio)
What size injectors would I need to run 15psi.
Old Apr 15, 2002 | 01:00 AM
sweettooth's Avatar
anybody? would 440's be enough? Also, how much boost will the turbo give max and where in the power band would I start boosting with a T3/T04E 46 trim?
[Modified by sweettooth, 10:02 AM 4/15/2002]
Old Apr 15, 2002 | 01:07 AM
SIK IN DA HED's Avatar
New User
ive heard that 440s is enough for 300 hp. if you expect to do more than that with 15lbs... go with 550s
Old Apr 15, 2002 | 03:54 AM
TurboSedan's Avatar
New User
Default Re: turbo question (dlplayboy)
Yep, 550cc would be a good idea for your application.
mytj2000
Feb 21, 2017 09:53 AM
88hbz6
Dec 24, 2007 02:58 AM
EJ8 GSR-T
Mar 28, 2006 04:09 AM
SPOON_BeIgHtEeNsEe
Jan 28, 2004 05:17 PM
civic5483
Jan 7, 2004 12:17 PM
