Turbo question
Old Apr 15, 2002 | 12:07 PM
JMinSi2000's Avatar
Default Turbo question
What do i need to do to this hole? Is it the one that needs to be run to my wastegate?
[Modified by JMinSi2000, 9:07 PM 4/15/2002]
JM Performance's Avatar
Default Re: Turbo question (JMinSi2000)
[QUOTE]Is it the one that needs to be run to my wastegate?QUOTE]
yep
Old Apr 15, 2002 | 12:13 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Turbo question (00SilverLS)
Yeah....that runs to your wastegate....tells your wastegate to open at a certain psi.
Here's a pic of my hose runing to the Deltagate with my $4 MBC.
Old Apr 15, 2002 | 01:47 PM
yellow blur's Avatar
Default Re: Turbo question (shamoo)
What are you supposed to run to the wastegate if the turbo doesn't have that hole? ie mine.
Old Apr 15, 2002 | 01:57 PM
Doodoo's Avatar
Default Re: Turbo question (yellow blur)
You can tap a hole in the charge pipe after the turbo inlet.
Old Apr 15, 2002 | 02:26 PM
JMinSi2000's Avatar
Default Re: Turbo question (Doodoo)
Where could I buy a fitting to go into that hole so I can run a hose to my wastegate?
Old Apr 15, 2002 | 02:27 PM
D-SPEED's Avatar
http://www.anplumbing.com
Old Apr 15, 2002 | 02:31 PM
JMinSi2000's Avatar
Default Re: Turbo question (D-SPEED)
What kinds businesses sells those because i'm lookin to buy one locally.
Old Apr 15, 2002 | 02:33 PM
maxim's Avatar
Isn't that port on the wg supposed to go to a vacuum source like on the fpr line? I don't have a hose going from the fitting on the side of my compressure going anywhere, it just vents to the air. I'm confused.
BTW. I have a Tial 35mm.
Old Apr 15, 2002 | 02:37 PM
D-SPEED's Avatar
Default Re: Turbo question (maxim)
the side port of the wastegate is supposed to be hooked up to a boosted source. I have heard people say it is better to have it pre throttle body, but others say it doesnt matter. While in boost it wont matter because the entire intake tract will be under pressure. If you dont have anything on that fitting on your compressor, make sure its plugged up.
MikeNice
Jul 16, 2007 04:15 PM
2LiterTurboSeR
Apr 19, 2006 12:33 PM
lowpsi
Dec 21, 2002 01:48 PM
