NEED QUICK ANSWER ON INJECTOR INSTALL
Old Apr 12, 2002 | 10:29 AM
93LSivic's Avatar
Default NEED QUICK ANSWER ON INJECTOR INSTALL
Ok, Im putting my rc 550s in right now. What steps do i take to make them seat into the manifold properly.
I tried searching and didnt find ****!
NEED SOME QUICK ANSWERS!!
Old Apr 12, 2002 | 10:33 AM
Ri5e's Avatar
Default Re: NEED QUICK ANSWER ON INJECTOR INSTALL (93LSivic)
gooto my website:
http://www.turbointegra.blike.com
then click on how to, then click on install injectors.
Old Apr 12, 2002 | 10:51 AM
93LSivic's Avatar
Default Re: NEED QUICK ANSWER ON INJECTOR INSTALL (BG Boost)
Ok, but on the 550s the rubber manifold seal seems too small. Also under the rubber seal there is a plastic washer with what looks to be the same ID as the rubber one--basically it wond let the injector slide past that-just the rubber seal.
PLEASE I NEED THIS DONE BEFORE I AM LATE FOR WORK!
Old Apr 12, 2002 | 11:12 AM
Speed PHreak's Avatar
Why can't you use your stock intake manifold seals?
Old Apr 12, 2002 | 11:13 AM
93LSivic's Avatar
Default Re: NEED QUICK ANSWER ON INJECTOR INSTALL (Speed PHreak)
I am, it seems like the base of the RC is larger than the stock one
Old Apr 12, 2002 | 11:15 AM
X2BOARD's Avatar
Search function not working too good, but there was a post on this a few days back.
Old Apr 12, 2002 | 12:03 PM
93LSivic's Avatar
Thanks everyone I got it.
All you gotta do is slowly tighten down the fuel rail onto the rubber cushions. But you also have to put a couple of washers onto the studs where the rail bolts to the manifold because it doesnt go down as far as the stock injectors will let it.
blakacintegra
May 22, 2007 09:18 PM
1badteg
Apr 18, 2007 11:15 AM
ultimatehonda
Jun 21, 2005 03:55 PM
whiteblurr
Feb 8, 2004 09:40 AM
Mucackus
Apr 23, 2002 06:33 AM
