quick dsm injector help, middle of install
Old Apr 27, 2003 | 06:09 PM
acman1's Avatar
Default quick dsm injector help, middle of install
ok, the injectors (450cc) r in, just wanted to know what i should set the safc at. i dont have the turbo installed yet, i just wanted to save myself some time for next weekend wen i install the kit...i figured -46 since thats what it would b stock rite? i set it at that, but it idles really low, and i get a metal sound wen i accelerate kinda hard (detonation?). do i need to set it up at -40 (same settings as when turbo is in)?
Old Apr 27, 2003 | 06:35 PM
acman1's Avatar
Default Re: quick dsm injector help, middle of install (acman1)
ne 1 know? i kinda need to no in a hurry...
Old Apr 27, 2003 | 07:38 PM
Poop111444's Avatar
http://www.geocities.com/therm....html
Old Apr 27, 2003 | 07:52 PM
acman1's Avatar
Default Re: quick dsm injector help, middle of install (si_mekanik)
so r the settings gonna b the same? i dont have my turbo installed yet. i set it to -38, but i still have that metal sound wen i accelerate in 3rd nd 4th gear, not in 1st and 2nd though.
Old Apr 27, 2003 | 08:03 PM
_Endless_'s Avatar
i'm not sure if you can hook it up without the turbo. you have already set it very low at -46 and you still have that metal sound so i guess it's not a good idea to run it this time. why not just wait til you got the turbo just to make sure nothing bad will happen to your engine when you drive it now.
Old Apr 27, 2003 | 08:11 PM
Mr. Softee's Avatar
Default Re: quick dsm injector help, middle of install (_Endless_)
ive found low idle in the past to be due to leanness and a little higher idle from running rich. even when NA i had to lean out my idle to get it to lower idling high.
Old Apr 27, 2003 | 08:44 PM
JalopySiR's Avatar
You can run this setup w/o turbo. I am currently running it. my settings are -35% lo, and -20% high. I'm sure i'm hella rich at WOT, but I really don't care...turbo going on soon enough... when in doubt just play with it. I had to toy for a while...you'll get it.
Old Apr 28, 2003 | 02:04 PM
acman1's Avatar
Default Re: quick dsm injector help, middle of install (JalopySiR)
now im really ******* confused...if im detonating w/o boost w/ my safc set at -35, how am i gonna boost at all? i thought that u couldnt set the safc ne lower than like -30 w/o it throwing a cel. does it have more to do w/ timing or what?
lookout22
Jan 9, 2009 06:32 AM
FERIO916
Dec 4, 2008 11:10 AM
youdontneed2cams
Feb 20, 2008 02:11 PM
acman1
Apr 30, 2003 05:31 AM
turbod16y8
Mar 20, 2003 04:30 PM
