GREDDY turbo kits
GREDDY turbo kits
looking around at all the pre fab kits out there the greddy seems to be the most user friendly and complete...looks like very good quality compared to drag
couple ?'s tho...do you just plug in the "blue box" and go?
is it safe to run the kit without an IC or BOV?
does anyone have experience with greddy turbo kits?
Re: GREDDY turbo kits (JeremyL)
I personally would never run without a bov. I've ran with no intercooler before and i'll never do it again. It's so much better with a intercooler. safer and more power.
How much boost do you plan to run?
i did my friends Greddy kit on his brand new GSR block from Acura and he is boosting 7 lbs on low boost & 10 on high.
he basically is running the blue box until he gets Hondata this summer
its ok except for the always present Check Engine light
but is plenty strong
but geta blowoff valve & intercooler
I have a 99 ls and my engine light is always on also. I have been through 2 new blue boxes from greddy and have tried someone elses, and still get misfire codes. The kit is very nice though. 13.7@103 w 2.2 60ft. stock clutch and tires
Re: GREDDY turbo kits (99lspwr)
come on dude 13.7 on a "stock" greddy kit on an LS? is it the IC'd kit? how much are you boosting? do you have any other mods in addition to the turbo?
Come on dude what!!!, You have been asking for our opinions and suggestions and I gave you mine. If you read my reply it said stock clutch and tires. Just in case you wanted to know, I am running an intercooler as well as a greddy evo cat-back. The boost is set at the stock greddy setting of 8 psi...
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">Come on dude what!!!, You have been asking for our opinions and suggestions and I gave you mine. If you read my reply it said stock clutch and tires. Just in case you wanted to know, I am running an intercooler as well as a greddy evo cat-back. The boost is set at the stock greddy setting of 8 psi...</TD></TR></TABLE>
you're in the 13s with stock clutch and tires. and still running a cat? lordy i need to get to the track and the dyno!
Re: GREDDY turbo kits (falconGSR)
just seems like a very low 1/4 time for 8lbs out of an 18g turbo on an otherwise stock LS motor...especially for stock tires
i like the greddy kit. personally i bought an i/c and bov. no problems with the kit at all, very reliable. it's been close to 5 months and still running strong.. im using the blue box
it's not so much "plug-in" for the box, you have to wire it up to you ecu.
As for running non-intercooled, I did for 6 months without any problems except for the awful turbo lag.
The BOV is a must to me although there's a wastegate. Not only for the sound, but for the extra comfort knowing that I won't have blow back.
But make sure you get the ic, I have the greddy type 31 ic and it made a huge difference in performance and temps
Re: GREDDY turbo kits (civicshowracing65)
99lspwr:>>
i had the same issue. with the mis fire codes.
check your spark plug gap. it fixed min.e
platinum
platinum
Re: GREDDY turbo kits (APEX i GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX i GSR »</TD></TR><TR><TD CLASS="quote">he basically is running the blue box until he gets Hondata this summer
its ok except for the always present Check Engine light </TD></TR></TABLE>
I have the greddy kit in my GSR but never had the check engine light come on maybe something is wrong. I have a little back fire but regap the spark plugs and it was fine. And for 13.7 in a stock LS i hope I can run that when i test my car.
