How Bad: No DP, and 02 unhooked?
First off, I know there have been topics on this, but search doesn't use 2 letter words... Secondly, how bad is it driving around with the turbo just dumping into the engine bay? Also, this would of course lead to not having an 02 sensor, what will this lead to? Thanks for any help...
Re: How Bad: No DP, and 02 unhooked? (JalopySiR)
It will stink, run like ****, make lots of noise, and **** off the neighbors.
Do it.
How far do you have to drive it?
Sonny
Do it.
Sonny
check engine light
loudness
i guess keep the car in low rpms and get the downpipe on.
dont' drive to long without it.
loudness
Re: How Bad: No DP, and 02 unhooked? (BoM)
I used bailing wire to attach an oxygen sensor to a turbo outlet...it wasn't that loud, really, since the sound bounced around in the engine bay and it pulled like a raped ape, BUT I ruined the o2 sensor in short order (week or so) because the fresh air reference port which is usually out of the exhaust gas got all clogged with soot...so, I'd suggest some sort of DP, but THAT will be louder than none if you don't attach it to the exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR »</TD></TR><TR><TD CLASS="quote">First off, I know there have been topics on this, but search doesn't use 2 letter words... Secondly, how bad is it driving around with the turbo just dumping into the engine bay? Also, this would of course lead to not having an 02 sensor, what will this lead to? Thanks for any help...</TD></TR></TABLE>
i did this a few weeks ago..loud, sound like some kinda fucked up lawnmower..stink as ****..and melt your fan
Re: How Bad: No DP, and 02 unhooked? (Sonny)
I think the neighbors already love us... My brothers exhuast snapped, thank you monroe. The cat is the muffler. Sounds nasty. What if I were to have a piece of tubing welded to the flange, then cut off the stock "B" pipe, just after the the 2 pipes merge into one, and just clamp some flexi-tube for a while? Hrmmm....
SLowCrx
16
02-18-2005 09:14 AM
crxtreme27
03-26-2003 07:04 AM
