What resistance does OBD1 ecu expect from injectors?
Re: What resistance does OBD1 ecu expect from injectors? (hybridb18)
ok, i found on hondata's website it says that the ecu expects 10 ohms. Then why are most stock 240cc injectors read about 12-13 ohms? Or is hondata wrong?
The resistance value is a minimum value.
Most peak and hold injectors are 2.5 to 3 ohms. The Honda resistor boxes are 6 to 8 ohms. The ECU expects to see as little as ~8-9 ohms. I've used that combo (DSM injectors [2.5 ohms] + resistor box [6 ohms] = 8.5 ohms) with no trouble. I've used stock Honda injectors (12 ohms) with no problems. The RC 440's that I ran were 16 ohms. No problem there either.
Sonny
