Will this heat shield clear the block?
You guys think this will clear the block? It's a heatshield for the turbine... I"m using a inlinepro. b18b, sc34...
http://checkout.verisign.com/c...19395
... how is your turbo oriented (turbine-compressor or compressor-turbine)?... if it is turbine-compressor (viewed from the front of the car), you might have a better chance of block clearance?
*edit* - turbine-compressor - compressor on the driver's side
