turbo installation problems >_<
Old Apr 26, 2003 | 10:49 PM
ash.zero's Avatar
Default turbo installation problems >_<
ok, starting installing yesterday (friday).
everything went well, but i can't find the oil feed source (the engine's f23a from 99 accord 4cyl). i found some sites/search results which says it's near the oil filter on the back of the block. check this pic out:
ok, thinking that thing has to be it, i pulled the rubber cover off. inside, i see a thin plastic piece connected to it. so i start unscrewing it, but the line keeps on twisting and it's not coming off, but i'm thinking "whoa, hold up". i'm guessing you have to unbolt the metal hex nut/bolt on the bottom? someone please help me with this issue. some detailed steps/explanations would be sooo helpful!
ok, second problem. i already have vafc and i'm planning on running afc hack, so i got blue top dsm 450cc's (obd1). this **** will not plug into injector clip. clip on the injector is way too big for the obd2 clip from my car. i was madly cutting the inside of the injector, but i still can't get it to fit. also, i was trying to take the white/clear cap thingy (pintle cap?) from my stock injector to put on the dsm's, but in the process of it, i managed to break on of them. is that piece necessary? also, if i put the cap back on to my stock injector and back to the intake mani, will it come off the injector and fall into the intake mani? please refer to this pic:
can someone please help me with these issues? how can i make dsm's fit? also, if i can't, then what are my options?
yesterday was a breeze, but today's install has turned to ****! any help will be greatly appreciated! tia!
Old Apr 26, 2003 | 10:52 PM
Mase's Avatar
Default Re: turbo installation problems >_< (ash.zero)
just pull the oil pressure sensor cap, it comes off.
you need new injector clips
Old Apr 26, 2003 | 10:56 PM
Trial User's Avatar
As for the oil line, yes that is it. You just unscrew it from the base and screw it into the adapter.
I think you need OBD1 connectors for the injectors. I had to trim my DSM's on the inside to fit. There is a strip of plastic on the inside that permits the Honda connectors from clipping in. I'm not sure if your OBD2 clips are different from my OBD1, but I think they are.
Old Apr 26, 2003 | 10:57 PM
ash.zero's Avatar
Default Re: turbo installation problems >_< (Mase)
new clips? is that the only viable solution? if i keep on cutting away at it, would it work? anyone in nova area wanna sell me a clip which will work? i need it tomorrow!!! argh! this is driving me nuts!
Old Apr 26, 2003 | 11:00 PM
ash.zero's Avatar
Default Re: turbo installation problems >_< (RACECAR)
yea, i took that strip of plastic, but even with that taken care of, the dsm's are too fat for honda clips!
Old Apr 26, 2003 | 11:02 PM
Trial User's Avatar
Yeah, that is because you have OBD2 clips. You can find OBD1 clips very cheap. I had to do very little trimming. It took about 15 seconds per clip with the dremel. I guess if you can grind the OBD2 clips down far enough it would work.
Old Apr 26, 2003 | 11:24 PM
ash.zero's Avatar
one more question:
can dsm injector be used without that clear/beige/white cap? (from stock injector)
Old Apr 27, 2003 | 06:53 AM
ash.zero's Avatar
anyone?
Old Apr 27, 2003 | 07:47 AM
bretx0r's Avatar
yes
Old Apr 27, 2003 | 11:31 AM
acman1's Avatar
yeah, i didnt realize i needed obd1 clips also. theres no way ur gonna get it to work w/ those obd2 clips. i found mine today at a junkyard...
Old Apr 27, 2003 | 11:35 AM
r4adkshn1's Avatar
Default Re: turbo installation problems >_< (acman1)
obd0 clips will clip right on those dsms FYI
no mods necessary.
Old Apr 27, 2003 | 01:49 PM
Hybrid's Avatar
Default Re: turbo installation problems >_< (r4adkshn1)
dude and your putting on a turbo?...............................bahhhaaaaaaaa
Old Apr 27, 2003 | 04:41 PM
dirtySOHC's's Avatar
Default Re: turbo installation problems >_< (Hybrid)
hope you got a resistor box being that you didnt know you needed OBD I clips.
Old Apr 27, 2003 | 05:06 PM
MikeMAN's Avatar
just pull very hard on the rubber boot and twist and it will expose the oil pressure sending unit. then just throw some teflon tape on the brass fitting and screw it in pretty tight. then connect ur sender to 1 of the open ports on the fitting, then the oil feed line to the next.
good luck with the install!
mike
Old Apr 27, 2003 | 05:44 PM
FBP Si 2000's Avatar
Default Re: turbo installation problems >_< (dirtySOHC's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC's &raquo;</TD></TR><TR><TD CLASS="quote">hope you got a resistor box being that you didnt know you needed OBD I clips.</TD></TR></TABLE>
He has one...I sold it to him.
white98gs-r
May 15, 2009 10:43 PM
nix94delsol
Apr 7, 2009 02:29 AM
1PT-SICK
Apr 18, 2006 07:27 PM
APEXI Si
Feb 21, 2004 03:50 PM
integranator
Apr 7, 2003 06:59 PM
