Don't understand EGT
Old Apr 29, 2003 | 09:37 AM
Kazz's Avatar
Default Don't understand EGT
I got 2 questions first, how do u read egt if its lean or rich and also second when i first installed my turbo supposely it was suppose to be the stock boost settings but it wasn't and i was running 20lb boost so i boosted once or twice but when i saw it went 20 i let go of the gas. Would that have ruined my motor?
Also my motor is stock and it was a greddy kit for gsr
Old Apr 29, 2003 | 10:28 AM
FFormula1's Avatar
Default Re: Don't understand EGT (JuuKe_EM)
EGT when plotted against AFR creates a bell curve, peak EGT occurs at ~15:1 AFR(stoichiometery), and falls off the richer or leaner the AF mixture. Therefore you really can’t tell if you are rich or lean unless you have an accompanying AFR meter.
Old Apr 29, 2003 | 10:32 AM
SOHC_power's Avatar
Default Re: Don't understand EGT (Muffin')
Correct me if I am wrong, but if the temp is too hot it is lean, and if it is too cold it is too rich.
Old Apr 29, 2003 | 10:39 AM
TurbodCX's Avatar
Default Re: Don't understand EGT (SOHC_power)
Not always.
over rich can show high EGT's as can low timing.The unburnt fuel burns in the manifold and it causes high EGT when it burns in the manifold.
Also Vaportrail has a really good article on here, search for that under his SN.
HTH
Brian
Old Apr 29, 2003 | 11:11 AM
Kazz's Avatar
Default Re: Don't understand EGT (TurbodCX)
then would i have ruined my engine if i boosted 20 lbs for 3 secs?
Old Apr 29, 2003 | 11:13 AM
psi420's Avatar
How did you boost 20psi on a gredyd kit? Forget to hook up wastegate?
Old Apr 29, 2003 | 11:15 AM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuuKe_EM &raquo;</TD></TR><TR><TD CLASS="quote">then would i have ruined my engine if i boosted 20 lbs for 3 secs?
it's possible, but does the motor make any strange noises, does it knock or tap, does it not have as much power, does it overheat, does it lose coolant or oil??
if the motor seems to be running properly than most likely nothing dramatic happened inside it. i would definantly check it out though.
Old Apr 29, 2003 | 11:16 AM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">Also Vaportrail has a really good article on here, search for that under his SN.</TD></TR></TABLE>
i'll have to check that out if it's still around.
Old Apr 29, 2003 | 11:31 AM
psi420's Avatar
check compression on your motor, make sure your rings and ring lands are still in good shape.
If it happened once maybe twice, you should be ok.
I boosted 13psi when i first hooked my kit up. Open downpipe - boost spike
Old Apr 29, 2003 | 12:00 PM
Kazz's Avatar
Default Re: (psi420)
Hey thanks for ya'll help guys
appreciate it
Old Apr 30, 2003 | 04:38 AM
TurbodCX's Avatar
Default Re: (JuuKe_EM)
Here ya go bro, here is the link to all of your answers on EGT's
https://honda-tech.com/zerothread?id=248965
HTH
Brian
Old Apr 30, 2003 | 07:19 AM
sweet's Avatar
Default Re: (TurbodCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">Here ya go bro, here is the link to all of your answers on EGT's
HTH
Brian</TD></TR></TABLE>
nice link there. good info.
Old Apr 30, 2003 | 01:08 PM
Kazz's Avatar
the wastegate was broken so it would never open for the air to go thru the downpipe. bought me a turbo xs one and its fine now . But the bottom has a funny sound now. I guessed it it phucked
Oleg
Jul 23, 2006 11:27 PM
turbo-d
Feb 4, 2005 04:58 PM
CiViC SiR
Jan 29, 2003 01:52 PM
syeve
Jul 13, 2002 03:33 PM
liam821
Feb 18, 2002 10:18 PM
