JRSC FPR setting?
Old Apr 29, 2003 | 03:45 PM
Tiamat-blue's Avatar
Default JRSC FPR setting?
K dumb question but how do I adjust the fuel pressure on my jrsc? I assume "tighten" the allen screw on the top of the FPR?
Old Apr 29, 2003 | 06:39 PM
Rory Breaker's Avatar
Default Re: JRSC FPR setting? (Tiamat-blue)
You can adjust Static FP by loosening the nut and turning the allen screw ccw/cw.
Old Apr 30, 2003 | 01:43 AM
Default Re: JRSC FPR setting? (newgsrdriver)
Ok that's what I thought, but which way? Cw to raise/ccw to lower I assume?
Old Oct 19, 2003 | 07:44 PM
Muckman's Avatar
Moderator in Chief
I have a friend with a JRSC Prelude SH. Off the shelf JR kit using the included FPR. Trying to tune the system and driveability just really really sucks. It was super rich and Ive learned it out a tune by adjusting the FPR and it doesnt smell rich anymore at idle and it idles better however it bogs and bucks like crazy under 3k rpm. Above 3k rpm it drives ok, but its slow, stock was faster without the supercharger.
Old Oct 19, 2003 | 09:08 PM
sharkcohen's Avatar
Default Re: JRSC FPR setting? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend with a JRSC Prelude SH. Off the shelf JR kit using the included FPR. Trying to tune the system and driveability just really really sucks. It was super rich and Ive learned it out a tune by adjusting the FPR and it doesnt smell rich anymore at idle and it idles better however it bogs and bucks like crazy under 3k rpm. Above 3k rpm it drives ok, but its slow, stock was faster without the supercharger.</TD></TR></TABLE>
But you still haven't rectified your MAP sensor issue that is causing your MAP CEL, which per our discussion is most likely a wiring issue at the JR "ems". You really shouldn't be messing with the static fuel pressure without a fuel pressure gauge, a dyno, and a wideband, and you shouldn't be boosting on it until you get fix all the installation bugs that you have. Be careful or you are going to blow your friend's H22 very, very quickly.
Old Oct 20, 2003 | 08:27 AM
Muckman's Avatar
Moderator in Chief
Default Re: JRSC FPR setting? (sharkcohen)
Thanks, I posted this question before we talked via PM. Fuel guage has been ordered and I am bringing in a friend who is very good at wiring and si going to go through and solder all the connections.
Old Oct 20, 2003 | 08:40 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I posted this question before we talked via PM. Fuel guage has been ordered and I am bringing in a friend who is very good at wiring and si going to go through and solder all the connections.</TD></TR></TABLE>
Sounds good, good luck with it.
Old Dec 8, 2003 | 06:24 PM
Muckman's Avatar
Moderator in Chief
I just want to find ONE JRSC user who has their car running GOOD with the JR FPR! Prove to me it can be done. I dont think it can.
Old Dec 8, 2003 | 07:14 PM
96IntegraRS's Avatar
It is possible... I'm doing it. I run a stock JR FMU, drilled regulator, and VAFC.
Hey just noticed that you are in Western MA? PM me and maybe I can help you figure it out - and no, I'm not going to steal your car
Old Dec 8, 2003 | 07:20 PM
Muckman's Avatar
Moderator in Chief
Default Re: JRSC FPR setting? (96IntegraRS)
Thanks but Im in NY. The original, the bigger Rochester!
Old Dec 9, 2003 | 06:10 AM
Justin95GSR's Avatar
i am getting ready to put one on my GS-R Sat. I will let you know then
Ultraman
Jan 31, 2007 08:38 AM
azhatch
Sep 5, 2002 10:34 AM
