Installing Front Mount Intercooler ON Teg.
Old Apr 27, 2003 | 06:01 AM
BlackB18CTeg's Avatar
Default Installing Front Mount Intercooler ON Teg.
I had a question about installing the front mount intercooler. I doesnt look too hard, except for the fact that there is this metal tubing type piece sitting right in front of the radiator . What is it and how do I get it out of the way. I have 95 Teg GSR. Any help would be appreciated. I am trying to piece together my kit one part at a time..... Thank YOu.
Old Apr 27, 2003 | 06:18 AM
APEX i GSR's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (BlackB18CTeg)
it depends on what kind of intercooler you have
if you are using the Drag you can just push it back out of the way
Old Apr 27, 2003 | 07:56 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Installing Front Mount Intercooler ON Teg. (APEX i GSR)
thats for your a/c, you can just bend it back towards th radiator.
Old Apr 27, 2003 | 09:19 AM
Mase's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (rewsnaeht)
be careful bending those a/c lines, they can break.
Old Apr 27, 2003 | 11:41 AM
Default Re: Installing Front Mount Intercooler ON Teg. (Mase)
Can anyone post their setups? I would appreciate it very much. I put my car on jack stands to see under there, and i promise that there is nearly no room. I posted some pics. One thing I noticed is that there are two raidtor type things. Layered on top of each other. Is this normal?
WHAT DO I DO WITH BAR AND LINES?
NO SPACE
SMALL GAP BETWEEN BUMPER BEAM AND LINES
Old Apr 27, 2003 | 11:45 AM
E-Rok's Avatar
EPIC TUNING
theres plenty of room, you put the FMIC under the bumper beam, not behind it. push the lines back towards the condenser and youll have plenty of room.
Old Apr 27, 2003 | 11:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">theres plenty of room, you put the FMIC under the bumper beam, not behind it. push the lines back towards the condenser and youll have plenty of room. </TD></TR></TABLE>
Old Apr 27, 2003 | 11:53 AM
B20LS-T's Avatar
New User
Those lines are for the Power steering, mount the I/C under the bumper support like mentioned. Have some L shaped brackets welded on if they are not already there.
E-Rok's Avatar
EPIC TUNING
You sir are correct.
Old Apr 27, 2003 | 11:56 AM
good stuff, i am about to go mount it now..... will post later on results
Old Apr 27, 2003 | 12:00 PM
woopdedoo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">
These are relays, not sure what specifically those control, could be A/C or headlights maybe. They can be relocated no prob.
Also, is that duct tape on your bumper support? Were you holding the intercooler up with duct tape? I thought I was the only one who did ghetto **** like that. Ghetto fabulous
Old Apr 27, 2003 | 12:21 PM
Default Re: Installing Front Mount Intercooler ON Teg. (vtec-elcamino)
nah, thats holding on the foam of my bumper to bumper beam. I dont need to reloacate taht stuff anymore since I found out where to locate Intercooler.
Old Apr 27, 2003 | 01:27 PM
SiRkid's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (B20LS-T)
small gap? that gap looks huge
Old Apr 27, 2003 | 03:02 PM
mskibbz-T's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (SiRkid)
careful with the AC line, mucho dinero
Old May 1, 2003 | 12:26 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
that is where to mount the intercooler? so the intercooler won't hang down too low if mounted fromthe bumper beam?
sorry, for the ignorant questions.. i just don't wanna mess this up.
Old May 1, 2003 | 01:11 PM
RyanAutry's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">
That's where mine is mounted.
Old May 1, 2003 | 03:46 PM
Default Re: Installing Front Mount Intercooler ON Teg. (RyanAutry)
should I mount on front or back of beam?
Old May 1, 2003 | 03:56 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">should I mount on front or back of beam?</TD></TR></TABLE>
Bottom
Old May 1, 2003 | 04:14 PM
io know under it, but should I hook the L tabs to the frong of the beam, or the rear of hte beam to hang it under.
Old May 1, 2003 | 04:23 PM
TurboB18C1's Avatar
i Installed a TYPE 24 Greddy Intercooler on my integ
I had to cut a peace of of my bumper support, here are some pics of them
RyanAutry's Avatar
Either. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">io know under it, but should I hook the L tabs to the frong of the beam, or the rear of hte beam to hang it under.</TD></TR></TABLE>
Old May 1, 2003 | 04:43 PM
kaj's Avatar
kaj
looks like i can just bend that one line in by hand, then (the one running in front of the others)
Old May 9, 2003 | 02:11 PM
anyone know how to drill the bumper beam? I couldnt, it was REALLY Hard......
Also where do you send the pipe through on the driver side? I cant find any room.....
Old May 9, 2003 | 02:15 PM
kaj's Avatar
kaj
we just used a regular drill on Ryan's. the metal isn't really all that thick on his. doesn't look too bad on mine either.
as for room for the tubing.. that's something i have to look forward to. by driver's side.. you mean intercooler tubing right?
Old May 9, 2003 | 02:16 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how to drill the bumper beam? I couldnt, it was REALLY Hard......
.</TD></TR></TABLE>
Are you serious?
It was like butta...
